Thread: A/C Compressor
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default A/C Compressor
    My air con is not working. Plenty of gas in the system (have had it pressure checked) but the compressor is not cutting in properly I think.
    With the car on fast idle (maybe 1000rpm) and I press the AC on, the revs climb slightly but no cold air.
    Have checked the fuses and changed the one for the AC (as found in the book) but still nothing.
    Is the compressor a servicable part or replacement part? And what is involved in changing it (I know the refrigerant gas has to be contained as venting to atmosphere is illegal?) but how hard is it to change or is there another fuse / relay that controls it?
    Getting annoyed with surging heat from the heaters on full cold in this weather.
    Regular Member F33F33's Avatar
    Nov 2009
    Preston
    Vehicle : Insignia
    Trim : SRi VX-Line RED
    Engine : 2.0CDTi
    Year : 2012
    As above!
    Had my aircon serviced and regassed yesterday after it wasn't working when I bought it.
    Was lovely and cold! This morning its back to warm air! The revs go up and I can hear the compressor / motor kick in when no radio is on.
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds like the electromagnetic clutch on the compressor may have burnt out. If you have a multi meter you can take the plug off the front of the compressor. When the button on the dash is pressed 12v should be there to energise the magnet
    Tain - Easter Ross
    Think I did that, maybe should have mentioned it!
    How easy / hard is the compressor to change?
    Tain - Easter Ross
    Quote Originally Posted by F33F33 View Post
    As above!
    You have a leak then!
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by RobW View Post
    Why change the whole compressor? You can just change the clutch on it's own
    Tain - Easter Ross
    Really??? Off to search ebay!!
  1. Air Con Compressor
    By Siggy08 in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2012, 15:52
  2. Air con compressor
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2009, 19:20
  3. air compressor
    Last Post: 18th November 2009, 07:56
