Results 1 to 10 of 11
Thread: Fog light fix! result! now temp guage thinks im in the sahara!
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default Fog light fix! result! now temp guage thinks im in the sahara!
    just thought i would share my 2 hours work to fix my dodgy fog lamp. for months now it has been coming up check left fog lamp. i knew it was not the bulb but another problem. got to the point where i canceled off the error and it came up straight away was driving the wife mad. so jacked up the car and commenced work.
    must have had the bulb in and out 20 times with no joy. then realised there was a plug in the lamp that unpluged pulled it out and got a mouthfull of manky smelly vile tasting wet crud! not impressed but thought this was it problem solved! cleaned it up put it back where it goes put my tools away let the car down and yep didnt work!
    put the car back up followed the wireing and found a big multi plug behind the bottom grill. pulled it apart and bingo all green and corroded. cleaned it up but ran out of wd. so done my best and all went well foglamp fired up.
    so went to get my daughter from her grans nd just realised my temp guage was reading 48C now i know the weather has been good but not that good!
    so need to check the plug out again in the morning as i assume the extra wires in it are for the outside temp. morral of the story check everything you fiddled about with! or you might be doing it again
    Regular Member Casper85's Avatar
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Engine : 2.2direct Z22YH
    Mileage : 54600
    lol, my offside fog lamp lense always seems to be steamed up, but has no cracks. My bro tells me this is a common fault with vectras. True???
    Engine : 1.9 CDTi
    Where is the big plug as my temperature displays about 6 degrees to hot all the time.
    West
    It's likely you have just disturbed the outside air temp sensor which sits in the lower grille, mine was knocked out of place whilst in for the dmf, found it hanging next to the rad picking up the heat from there lol...
    Nov 2010
    BRECHIN
    its attached to the right hand side of the bottom grill if your looking at the car. i can only assume ive not cleaned it out properly hence the dodgy reading now.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Quote Originally Posted by Casper85 View Post
    Yes mate common fault. Have a search as there are quite a few threads about it.
    3.2 v6 Signum and loving it
    Nov 2010
    BRECHIN
    its my nearside that suffers from fogging up. been told there is a breather kit you can buy to stop it happening
    West
    Quote Originally Posted by TimTay View Post
    yeah little snorkles for the fogs, got them on mine
    Engine : 1.9 CDTi
    Ah not my problem then as my sensor is connected and in the right place on the grill. I also replaced it with a new one to no avail.
    Nov 2010
    BRECHIN
    i assumed that after fiddleing round with that plug "not cleaning it properly" have done the equivelant of altering the resistance hence a dodgy reading. where does the sensor plug in then?
  1. 2.0 dti temp guage
    By stj in forum Engine & Drivetrain
    Last Post: 26th November 2013, 11:47
  2. temp guage ???
    By mauricemersey in forum Engine & Drivetrain
    Last Post: 23rd December 2012, 13:13
  3. temp guage and fog light problem
    By coooky in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2011, 08:17
  4. temp guage problem
    By sri-case in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 21:17
  5. Temp Guage - But already replaced :(
    By robert_dale in forum Engine & Drivetrain
    Last Post: 11th May 2010, 17:12
