Thread: hunting idle..camshaft crank sensor question
    Regular Member Fash's Avatar
    Doncaster
    Default hunting idle..camshaft crank sensor question
    Recently the ol' 1.8 (2003 club) has started hunting idling, i have given the throttle body a clean, and as I had the same problem on my bmw 318 a few months ago, I reckon it's probably down to the camshaft crank sensor (as it was on the bmw)...
    How easy is it to change on the 1.8 ecotec ? If it's easy, wherabouts is it on the vec (pic with diagram would be a great help), and finally what part number from vx is it, or would there be somewhere on fleabay suitable (prices?)..
    I'd rather do it myself if I could to save some ££££'s
    Thanks very much for your help,
    Cheers,
    Steve
    PS Mine doesn't have an egr valve either, so I know it's not owt to do with that
    Regular Member Jezzy's Avatar
    S.E
    Camshaft is at the top of the engine, crankshaft is at the bottom - which one do you mean to refer to?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The crankshaft sensor and camshaft sensor are the same thing. The ECU uses the camshaft sensor to calculate the position/speed of crankshaft. Calibrated to the position of piston/cams of cylinder 1, the other cylinders are worked out position wise from this. Speed of the crankshaft is just the speed of the camshaft multiplied by two.
    The position of the camshaft/crankshaft sensor is on the top of the engine at the end (clutch/gearbox side) of one of the camshafts going by my engine (1.9CDTI) anyway.
    S.E
    That depends on the engine - on mine there's a crankshaft sensor, but no camshaft sensor. The position of the camshaft is deduced by sending a small spark to each cylinder and seeing which one reports back that the cylinder has air/fuel mixture in it.
    Doncaster
    Yeah I think it's probably just the one sensor-any idea where it is on the 1.8 ecotec ?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Camshaft sensor is on the top between the cam timing sprokets thingys(sorry cant remember there proper name). Remove the covers and its just 2 screws that hold it in and is easy to change.
    Doncaster
    thanks mate. dont suppose you have a picture please? and wheres the best place to buy a replacement?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    http://www.ebay.co.uk/itm/VAUXHALL-A...3#ht_687wt_698
    Thats basically it there. Was trying to find teh how2 for the z18xe but cant see it, im sure there would be a picture of its position in there.
    Doncaster
    thanks mate, will get one on payday..just need a pic of it in there for clarity and away i go
  1. occasional slow idle, hunting, missing?
    By dahmich in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2012, 21:12
  2. 1.8 club hunting for a few secs when idle..help
    By Fash in forum Engine & Drivetrain
    Last Post: 31st August 2011, 18:23
  3. Hunting idle on 2.0t
    By Morephun in forum Engine & Drivetrain
    Last Post: 17th June 2010, 12:35
  4. 2005 2.2 Design Auto, rev hunting on idle, and misfiring
    By PhilMac750 in forum Engine & Drivetrain
    Last Post: 5th May 2010, 17:21
  5. 2.0 T hunting on idle
    By stephen g in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2010, 20:33
Z18XE cam crank weiform
crankshaft sensor location 2011 1.8 ecotec
vauxhall z18xe hunting at idle and misfires
vectra b 1.8 eco crankshaft sensor location
vectra 1.8 ecotec crank sensor site:www.vectra-c.com
1.8 z18xe crankshaft sensor
vectra c 1.8 2005 crankshaft sensor
z18xe cam sensor
vectra c crank sensor calibration
vectra c 2.2 petrol crank sensor site:www.vectra-c.com
z18xe camshaft sensor location
z18xe crank sensor location
