Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: Failed M.O.T Today
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Default Failed M.O.T Today
    M.O.T Today And Failed On Emissions
    Description Limits Actual Value
    Fast Idle Test Manual Check
    Lambda: 0.970-1.030 1.151 Fail
    Second Fast Idle Test Manual Check
    Lambda: 0.970-1.030 1.298 Fail
    4 Advisorys
    002 Offside Front (Outer) Front Constant Velocity Joint Gaiter Deteriorated
    003 Rear Brake Caliper Anti-Rattle Spring Missing
    004 Brake Pipes Greased Over
    005 EML On
    Booked Back In For 2:30 Pm Tomoz
    ******* Advisory For Greased Brake Pipes/Rattle Spring Missing...WTF ???
    Bought A 475Ml Bottle Of Cataclean...
    I Am Running On Fumes Just Now So...Need To Know How Much Petrol To Put In Per Bottle Of Cataclean...Also...How Long Do I Drive It For ???
    And Do I Rag The Arse Off It ??? lol
    You Think It Will Work ???
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I used to let the fuel level come down to about 1/8 tank on the Senator and Omega... pour in the full bottle.... go for a decent drive - I went home to Thetford and back which totalled around 30 miles and included tootling around town at low speed, then back home on a 56mph cruise as much as possible.
    Then fill as required with good quality (non-supermarket) fuel and arrive for your MoT appointment with the car fully at temperature.
    One additional point just to get my full moneys worth - make sure your bottle of Cataclean is nice and warm before you put it in the car..... less left in the bottle !!
    Engine : 1.9 CDTi
    Get the cat as hot as possible for the test. Also what is your air filter like?
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Tam if the EML is on you'll be able to read the codes using the pedal test mate.
    Aug 2010
    Dundee-Motherwell
    Quote Originally Posted by Handyandy-UK View Post
    Will Even Leave It Running When I Get To Garage As Well
    Did It Work For You ?
    How Does My Figures Look...Is It Out By Much ?
    Quote Originally Posted by lee gsi View Post
    Air Filter Was Changed Bout 6 Mths Ago Mate
    Have Checked The Code With My U480 Mate...Canny Mind What Code Was But If I Seen/Heard It Again I Would Know It...Summit To Do With Bank Threshold Or Summit
    Engine : 1.9 CDTi
    Bank threshold sounds like a lambder sensor problem or air leak.
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Cataclean worked very nicely on both the Senator and Omega.
    Of course it helps if there are no underlying faults as well, but on a decent but dirty system it brings the numbers down very nicely indeed.
    Regular Member Jezzy's Avatar
    S.E
    Cataclean should be used with a quarter tank of fuel or even a bit less. Then drive it enough to use up virtually all that fuel, then fill up with good quality fuel (not Tesco/Sainsbury 95 RON). As you have a petrol engine, change the spark plugs.
    Aug 2010
    Dundee-Motherwell
    Would Putting In A New Sensor Help This If Its Still Out With Cataclean ?
    Much We Talking ?
    Cool
    Good Stuff Jezzy Cheers Mate...Only Changed Plugs Last Week
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    inlaws vec had the same fault was the second lambda that was at fault. sweet as a nut now minus the rough running due to wrongly fitted timing belt.
  1. Failed MOT today, just one item
    By DieselHead in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2011, 13:55
  2. my vec failed its test today :(
    By barrymanalow87 in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 14:48
  3. MOT failed today
    By L11Marc in forum Vectra C / Signum Troubleshooting
    Last Post: 7th December 2009, 21:29
  4. mot today and failed
    By bigron1988 in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2009, 19:32
  5. Car failed first MOT today.
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2007, 16:01
