Results 1 to 10 of 11
Thread: any help appreciated....................
    Gloucester
    Default any help appreciated....................
    drove to airport in the rain and the windows started to mist up
    put the blowers to windscreen and on full........................nothing, didn't even attempt to clear
    (great fun on the motorway................NOT!!)
    the only way it would clear is with aircon on
    now thats not to bad in this weather, but its gonna be crap (and cold) in the winter.
    any ideas?
    Sunny Dartmoor
    You need to change your pollen filter,there about a fiver on ebay.....
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Make sure your pollen filter is clean.
    I have always found the best way to clear the screen is with the aircon on in all the cars I have had. Did you turn the heating up when you put the blowers onto the windscreen? If you used cold air then it would have still been moisture laden and therefore woudl not have helped.
    I had a Ford once that actually shut down the windscreen vents when the pollen filter was full. It always happened on a wet day as well!
    Jul 2009
    The Rift, Cardiff
    As said replace pollen filter. It's also worth checking the drain holes in the scuttle tray, they block easily and the water can soak the filter and breach the cabin.
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    Might sound daft, but you haven't got the heater on recirculate have you? If you have it can cause a car to become very moist on rainy days as there is no 'clean' air entering the cabin.
    Regular Member Jezzy's Avatar
    S.E
    "Recirculate" automatically disengages when you direct the air flow at the windscreen.
    Jun 2011
    South Shields
    Ah! Well, can't be that then...
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    leave air con on all year and just turn the temperature up in the winter.
    lincolnshire
    defo pollen filter , cheap to change , easy to do and the results are instant ,get it swapped asap
    Gloucester
    thanks peeps
    ummmmmm........................................whe re's the pollen filter?
  1. your help would be most appreciated
    By bigbow in forum Bodywork & Interior
    Last Post: 14th November 2012, 23:41
  2. poor mpg any help appreciated
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2010, 13:48
  3. Help appreciated
    By mickyg in forum Vectra C / Signum Troubleshooting
    Last Post: 14th May 2010, 15:51
  4. speedy help appreciated!
    By AKeeNShoT in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2010, 12:49
