Results 1 to 10 of 17
Thread: Cased front break discs help PLEASEEE
    Mar 2011
    dunfermline
    Default Cased front break discs help PLEASEEE
    Whet to change front breaks today all was going well till it came time to remove front discs. there r stuck fast and despite pounding on them for over a hour they would not move any ideas
    Northampton
    Engine : A20DTH
    Mileage : 88000
    spray WD40 into the bolt holes and try and get it between the disk and hub. Leave it for 20 mins then give it another bash.
    I am assuming you removed the little torx screw
    When all else fails use an angle grinder, just make sure you dont damage the hub.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Could also heat up the disk with a blow torch to try and get the disk to expand
    Mar 2011
    dunfermline
    Yes removed nub screw and tryed heating disc still na joy thinks me will have to go to garage
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Take an angle grinder to it. Cut from one wheel bolt hole to the outside. Hopefully that will generate enough heat to get off put allow you to get more WD40 between the hub and disk.
    Mar 2011
    dunfermline
    Ye will go buy one 2moro what a pain tho
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by datiger79 View Post
    Feel for you bud, should be an easy job but it never happens that way unless you are doing it for someone else then it goes perfect
    Mar 2011
    dunfermline
    Ye just hope i dont hit hub
    11 Post(s)
    Oh dear!! Prepare yourself for future wheel bearing failure.
    http://www.car4play.com/forum/post/index.htm?t=6462
  1. Thoughts again... but on break discs
    By lew1984 in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2011, 02:04
  2. front discs
    By edwardabud86 in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2011, 21:08
  3. veccy front break pads
    By G4GAV in forum Handling & Braking
    Last Post: 22nd July 2010, 08:44
  4. Replies: 1
    Last Post: 21st October 2008, 15:11
  5. Help,,, please, with front discs!!
    By mitch1965 in forum Handling & Braking
    Last Post: 10th September 2008, 22:36
