Thread: Automatic gearchange slow
    Nov 2010
    Northampton
    Default Automatic gearchange slow
    Hi everyone,
    On my Siggy 1.9 150hp the auto box doesn't want to go up into 2nd very quickly, not until up to 3000rpm, unless I use an extremely light touch on the gas.
    Is this normal? It's certainly not like previous autos I've driven. I end up switching into manual override as soon as I move off, in order to get 2nd gear. Could it be a sensor - any other ideas? All other gearchanges seem OK.
    Otherwise a brilliant car!
    Cheers,
    Rog
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Not up on Siggy's, but my Vectra doesn't suffer from that at all.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    What milage mate?
    Has it had gearbox oil an filter change?
    Does it change smooth when done manually?
    Nov 2010
    Northampton
    Generally changes are smooth, unless I go up or down several in quick succession - my impatience I suppose. It's got full service FWIW, but do you think the oil and filter change would do it - been the same since I had the car last November. Oh, 46K on the clock, 06 plate.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Could be a couple of things.
    If you change to quick you can sometimes not give the box enough time to catch up.
    I'd go first with changing oil an filter as it's reativly cheap an rules that out.
    But sometimes delays can be caused by torque converter ( basically automatic version of a normal clutch)
    Nov 2010
    Northampton
    OK, will try that first. Otherwise must drive according to my age!
    Cheers,
    Rog
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Mine does something similar but only when stone cold does yours do it all the time?
    Oct 2010
    London
    Mine is a bit slow on the up-shifts when cold but afaik it does it to warm the box up. When it's hot it shifts up when it is supposed to... unless I nail it!
    Nov 2010
    Northampton
    Quote Originally Posted by paulhb View Post
    Yup, all the time - hate screaming engines when I'm getting nowhere, good job the torque is there for a quick switch into 2nd.
    Guess I'll put up with it until the next service, then get the oil and filter changed.
    So does yours change quickly into 2nd when it's warmed up?
  1. automatic gearchange
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2010, 22:54
  2. Gearchange linkage
    By Readster in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2009, 21:07
  3. Gearchange- what to check first?
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 13th November 2008, 20:59
  4. Notchy Gearchange
    By BigP in forum Engine & Drivetrain
    Last Post: 1st February 2007, 20:11
  5. Stiff gearchange
    By monkeybusiness in forum Engine & Drivetrain
    Last Post: 19th January 2007, 18:58
