Results 1 to 3 of 3
Thread: 1.9cdti won't start!!
    Jul 2011
    Liverpool
    Default 1.9cdti won't start!!
    Hi all, got a 2005 1.9cdti (120) that will not start. Had engine diagnostics done and they came up that the glo-plugs were on their way out but it could be the battery also. Changed the battery and replaced all 4 plugs last week and started ok(ish). Yesterday and today needed a jump start! Car "wants" to start but after a minute or so of cranking the engine the battery dies. Don't think the is a current gettin sent to the glo-plugs could it just be the relay that needs replacing? Driving me crazy as I had to replace the steering rack recently so not exactly flush with cash at the mo. Any advice would be a great help.
    lincolnshire
    unlucky matey , sounds like a wiring issue of some kind ??
    South Central England
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I'd start by checking that the trottle valve has not failed and jammed closed, then dump all the fuel, check the filter and refill it. If there are no more fault codes, it will be a pain but water in the fuel creates and intermittent starting fault. Don't crank the starter motor for more than ten seconds at a time and give it 30 seconds to cool before trying again.
  1. where to start with a 1.9cdti 150?
    By bigdave1701 in forum Diesel Engine related
    Last Post: 27th July 2011, 20:07
  2. vectra c 1.9cdti - help car cut out and won't start!
    By morris in forum Engine & Drivetrain
    Last Post: 8th December 2010, 18:03
  3. wont start 1.9cdti
    By otl1uk in forum Engine & Drivetrain
    Last Post: 19th November 2008, 20:11
  4. 2006 1.9CDTI SRI 150 Won't start!
    By Rmac1 in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2008, 21:36
  5. 2006 1.9CDTI SRI 150 Won't start!
    Last Post: 3rd August 2008, 18:39
car wont start 1.9 cdti
