Page 1 of 7 123 ... LastLast
Results 1 to 10 of 68
Thread: Agro with front parking sensors, Help
    Full Member lizard's Avatar
    Oct 2006
    southampton
    15 Post(s)
    Default Agro with front parking sensors, Help
    Right, I have fitted aftermarket parking sensors to a switch in the car, now, I have wired them to an ignition live and they all work fine when the ignition is on but engine off but when the engine is on i get a constant beep. any ideas anyone, oh and i also tried direct to the battery too. the company that supplied them said it was the Canbus only i cant see how this would affect them tbh. where did anyone else wire them too and not get this problem please....
    Admin plasma's Avatar
    On the Forum
    267 Post(s)
    Engine : 150
    Mileage : 74000
    what kit are they and where did you pick up the power supplies from?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Oct 2006
    southampton
    15 Post(s)
    Here's the kit, same as i have in the rear with no problems, and the power was taken from ignition live in the under bonnet fuse box, also tried direct battery too with the same result, as i said, fine with engine off Dean....
    On the Forum
    267 Post(s)
    Engine : 150
    Mileage : 74000
    where have you picked the Earth/negative from?
    (popping out for a bit, back in an hour)
    Oct 2006
    southampton
    15 Post(s)
    Earth is direct to battery and live ill have to look later, piggy backed from under bonnet Dean, any ideas where the best place to feed from...
    Slough
    72 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    had this with mine ,beep beep when driving along . in the end i just disconnected them , khalid
    the vectra has gone , but not far away so ill still see it form time to time
    Oct 2006
    southampton
    15 Post(s)
    Quote Originally Posted by happypostie View Post
    Hahahahaha thats hardly much help to me is it Khalid, I want them working, can only be the live feed causing it somewhere...
    On the Forum
    267 Post(s)
    Engine : 150
    Mileage : 74000
    so with it connected to battery + and - its fine, but when engine running is the problem?
    Jul 2009
    The Rift, Cardiff
    hmm, maybe the engine running is causing some sort of interference if it works fine with just ignition on. Did you bench test them before fitting? Maybe you could test them one by one, disconnecting the one your not testing from the module, by pulling the sensors out from the bumper and see if they work normally a foot or so away?
    Oct 2006
    southampton
    15 Post(s)
    Done as you said Chris, tested each one and all fine with no engine running, as soon as you start it there's a constant beep... fitted them to the below fuse Dean if that sheds any light...
  1. Anyone got front parking sensors.?
    By montyfert in forum Bodywork & Interior
    Last Post: 7th June 2012, 21:55
  2. Front Parking Sensors
    By war222 in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2009, 13:33
