Thread: Air Conditioning question
    Regular Member Vectra Forever's Avatar
    Apr 2011
    Somerset
    Default Air Conditioning question
    Morning all,
    Just a quick question as this one keeps bothering me. On all my previous cars with A/C including my 58 plate Golf, when you put the A/C on the auxiliary fan starts up in the engine bay and runs until you turn the A/C off.
    On my 2.2DTI, when you switch the A/C on the aux fan(s) do nothing. Late yesterday I took it out for a run and it was 24 degrees so the A/C was on a lot. The car got right up to 90 degrees on the water temp but still neither radiator or the aux fan cut in.
    I have no fault codes, no warning lights and the fan blades seem to turn just fine. All connectors are plugged in too.
    Any ideas?
    Thanks – VF.
    Glasgow
    Was the air con blowing cold air? Did the car overheat? If the answer is yes and no there's nothing to worry about.
    Apr 2011
    Somerset
    Quote Originally Posted by byebyeitsagsi View Post
    The answer is Yes and NO. So I'm happy then and that's all that counts
    6 Post(s)
    Quote Originally Posted by Vectra Forever View Post
    On all my previous cars with A/C including my 58 plate Golf, when you put the A/C on the auxiliary fan starts up in the engine bay and runs until you turn the A/C off..
    On Vauxhall's it will come on as and when required. The fan won't run all the time.
    Full Member Big Sig's Avatar
    Its due to the pressure within the A/C system. If it rises to a high enough level it will start the fans, which will cut off below a set pressure.
    Apr 2011
    Somerset
    Thats good then. At least that means I don't have any problems. Happy Chappy
  1. Air Conditioning
    By scarydeath in forum Troubleshooting
    Last Post: 21st April 2012, 20:32
  2. air conditioning
    By marko1973 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2011, 21:37
  3. Stupid question about air conditioning
    By Jax in forum Heating, Ventilation & Air Conditioning (HVAC)
    Last Post: 3rd June 2010, 21:51
  4. Air Conditioning: Hot Air
    By barkzz in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2009, 20:28
  5. Air conditioning HELP!!!!
    By s0501291 in forum Engine & Drivetrain
    Last Post: 1st June 2009, 11:44
astra j air con engine overheat message
