Thread: cdti starting problem, air leak??
    Apr 2011
    essex
    Default cdti starting problem, air leak??
    HI, My 1.9cdti 8v has trouble starting on the first start of the day. Its had new glow plugs and fuel filter. At first I thought it was a bad set of glow plugs but have realised now it must be the fuel draining back to the tank. The reason I think this is that if you turn the ignition on and wait for the pre pump in the tank to stop running it will start,the pump seems to run for a long time too 30 secs ish. Has anyone got any ideas why the fuel is draining back? air leak? Is there a one way valve on the fuel system?
    Jun 2011
    Elland
    Don't know whether there is a non return valve, but on my V6 diesel, there are a number of 'quick release' joints on the fuel lines, some of which have failed. Agree that an air leak sounds like the culprit, so see if yours has any signs of quick release joints between flexi and rigid pipework (i.e. not permanently crimped) and see if there is any fuel leakage. Also make sure the fuel filter housing is sealing correctly and there are no signs of fuel leakage... cos if fuel is leaking out, you can bet air is getting in when it's all turned off!
    Apr 2011
    essex
    Thanks, the filter housing doesn't have any fuel leaks but there are quick release fuel pipes going to it. I will check them next.
    Jun 2009
    Dover
    My car is the same.I've heard that it could be hairline cracks in fuel filter housing.I need to take my car to the proper diesel mechanic but I haven't found any yet...
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    hairline cracks are normally referring to the dti's.... The CDTi fuel filter housing is under some pressure so any cracks/leaks will definitely be apparent
    Jun 2011
    Elland
    Check over the whole fuel lines in the engine bay, too. I have quick release joints elsewhere in the system, not just to/from the filter.
    Apr 2011
    essex
    Problem solved! I changed the leek off pipes and also fitted a new battery,now starts fine. It turns out the battery wasn't powerful enough for the car,although it seemed to turn over ok it obviously wasn't fast enough.
  1. 2006 vectra 1.9cdti starting problem and i=oil leak on start up
    By tomstubbings in forum Engine & Drivetrain
    Last Post: 24th September 2011, 10:01
  2. 1.9 cdti intermittent starting problem (air leak?)
    By moff747 in forum Engine & Drivetrain
    Last Post: 16th April 2011, 15:54
  3. 1.9 CDTI starting problem
    By dubsrus in forum Engine & Drivetrain
    Last Post: 27th April 2010, 16:02
  4. 1.9 cdti starting problem
    By reptar in forum Engine & Drivetrain
    Last Post: 25th January 2009, 21:37
  5. 1.9 CDTI 120 starting problem
    By SUBJAM85 in forum Engine & Drivetrain
    Last Post: 16th October 2008, 11:03
1.9 cdti air leak fuel filter
vectra c trouble starting air
