Results 1 to 3 of 3
Thread: Fault code help please
    Jun 2011
    United Kingdom
    Default Fault code help please
    Hi guys, the car keep idling funny and when the engine is under a bit of stress, such as going up steep hills, it seems to loose a lot of power, the revs sometimes drop for a few seconds then go back up.
    There was no management light on so I read the codes and got :
    P0170 Fuel Trim Malfunction (Bank 1)
    Any ideas what this means please guys ?
    Thanks very much
    The car is a 1.8 LS by the way
    Bristol
    Hi This code points to the 02 sensor on bank 1.
    Jun 2011
    United Kingdom
    Thanks very much for the reply mate, is this easy to change ?
    Ive a bit of experience behind me but this is the first time ive had a vectra.
    Also the car seems to idle quite high when first started, then drops back down, and sometimes its quite up and down when sat at lights etc.. would this sensor also cause these faults ?
    Thanks very much
  1. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  2. Fault code help!!!
    By billy88 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2011, 16:02
  3. help with a fault code
    By jan65uk in forum Engine & Drivetrain
    Last Post: 15th December 2009, 20:57
  4. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
