Thread: camshaft fault
    Jul 2011
    bicester
    Exclamation camshaft fault
    hey guys i have had a problem with my vectra c 2.0 dti 2002 spanner light comes on then goes into limp mode pluged in my software and has come up with a camshaft fail fault does anyone knoe were i can get a new one? and also were abouts it can be found ?
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    You sure its not cam shaft sensor fault?
    Jul 2011
    bicester
    sorry yes mate thats what it is cam shaft sensor fault
    Ely, Cambridgeshire
    60 Post(s)
    Year : 2010
    Lol, makes a lot more sense. Not sure where exactly the sensor is on your specific engine as I don't know that engine, but there will be a connector somewhere on the top of the engine connected to one end of the engine. Someone more familiar with the engine will be able to tell you quickly.
    Usually they are very easy and quick to change.
    Regular Member hagga's Avatar
    kingswinford
    Looking at diagrams etc for the 2.0dti there isn't a cam shaft sensor... maybe the crankshaft position sensor?
    Jul 2011
    bicester
    Quote Originally Posted by hagga View Post
    do you know were abouts the crankshaft sensor is located ?
    The crank sensor on the 2.0dti/2.2dti engine is screwed to the front of the engine block underneath the oil filter housing.
    kingswinford
    Quote Originally Posted by lee--1 View Post
    Quote Originally Posted by Rapala View Post
    marked in red
    Regular Member smirnoff sri-dti's Avatar
    Apr 2011
    London
    i had same problem with 2.2tid (saab)
    as soon as i changed sensor it went fine after that
    . now I also have a spanner showing on the screen but no limp mode
    so will need to double check
    Regular Member getmoney's Avatar
    Dec 2010
    In A BoX
    marked in red
    PICTURE above ***
    Can you PLEASE mark the position of the crankshaft sensor of a Vec - C 1.9 CDTI 120Hp. (European Car)
    What software do you use ( I have TIS 2000, but it's hard to work with. )
    car is doing weird ( looks like the symptoms of the crankshaft sensor problem. )
    So I would like to change this.
    THANK YOU
  1. Camshaft Woodruff Key
    By 123rado in forum Engine & Drivetrain
    Last Post: 2nd January 2013, 22:54
  2. cold start problems due to camshaft sensor fault ?
    By jaykay in forum Engine & Drivetrain
    Last Post: 15th June 2012, 19:05
  3. Camshaft
    By Rebellion8878 in forum Petrol Engine related
    Last Post: 3rd January 2010, 15:51
  4. camshaft removal help?
    By ectraz in forum Engine & Drivetrain
    Last Post: 30th June 2009, 14:00
  5. camshaft
    By darren klershaw in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2007, 22:18
