Thread: Battery Light
    Jan 2010
    wirral
    Default Battery Light
    Just driving home and my battery light has illuminated. It stayed on for the duration of the journey. When I arrived home, I switched the ignition off and re-started the car, and bingo.....its gone out again.
    Should I be worried or not? Has anybody any idea what the likely cause is.
    Got a good bit of driving to do tomorrow and don't fancy breaking down.
    Any ideas would be greatly appreciated.
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Get your alternator checked.
    Regular Member coooky's Avatar
    May 2011
    washington
    Quote Originally Posted by bafoo View Post
    Tomorrow after a little bit of driving it will more than likely come on
    mine comes on after a few miles and stays on even though the alternator is charging the battery,had it checked by the rac and the local garage the fault finder says its lamp charging generator = alternator rac said it might be on its way out but been fine for over 4 weeks now starts no problem
    Regular Member AndyCCC's Avatar
    Newcastle
    Defo check your alternator out.
    If you check in the book the light that looks like a battery is, in fact, the alternator!!
    Mine went last winter.
    Ely, Cambridgeshire
    60 Post(s)
    Year : 2010
    Technically, the battery light comes on when power is being drawn from the battery instead of the alternator which under any normal circumstances should only happen if the alternator has failed.
    Regular Member rustle's Avatar
    May 2011
    Lincoln
    Mine lit up on Friday with the spanner light & I'm currently waiting on the recovery truck to take me to the garage. The battery is dead so looks like its the alternator
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    defo alternator bud
    May 2011
    Lincoln
    Thought so, should be covered on my warranty though only had the motor 6 weeks, but it can happen to any car
    Jan 2010
    wirral
    What a nightmare, the cars just approaching the 100k mark and according to its service history, it has already had an alternator. How much are we looking at to replace??
  1. Replies: 4
    Last Post: 18th August 2012, 08:58
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  4. battery light on along with spanner through car light
    By conny in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2011, 13:45
  5. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
