Thread: code p1125 (61)
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default code p1125 (61)
    Does anyone know what the (61) means after the p1125 throttle actuator malfunction code, I get this now & again, Ive checked the solder joints on the throttle body close up with a magnifying glass & they all look good, Ive also made sure the body & flap are clean & not sticking, Any ideas if its the body at fault or pedal box ?.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    p1125-61 means the throttle actuator, its lokated in the enginecompartment.
    edit: look here http://www.saabscene.com/forum/lofiv...t31647617.html
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Yes i did google & that thread came up among others, But some did say just because it looks like its the throttle body it may not be, So i did wonder if the (61) was relevant to a certain part ie the throttle body itself, There is an actuator in the tb & the pedal box so was just trying to clarify ?, thanks for the link though.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Well been to Cornwall & back, its played up again a couple of times, throwing up the same code, it seems to happen from cold & within the first 5/10 miles then didn't do it again?, i did notice the odd blip where i presume the tb tried to close, could do with knowing for sure if the (61) relates to the tb or pedal.
    Engine : 2.2 Direct
    its in the engine compartment.. not the pedal.
  1. Fault code p1125 app system help please !!
    By WDUK2005 in forum Engine & Drivetrain
    Last Post: 8th August 2011, 16:36
  2. question on code p1125
    By collyb in forum Engine & Drivetrain
    Last Post: 24th April 2011, 15:34
  3. Code p1125
    Last Post: 23rd April 2011, 23:46
  4. fault code P1125 ??
    By cov in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2010, 12:10
  5. Oh Dear, How bad is a P1125 Fault Code
    By markm in forum Engine & Drivetrain
    Last Post: 11th September 2010, 23:07
p1125-61
Opel DTC P1125-61
p1125-61 vauxhall
p1125-61 opelp1125-61 vectra cvectra cofes p1125-61p1125-61 vauxhall vectrap1125-61 insigniaVauxhall p112561vauxhall zafira 2010 code p1125
