Thread: smoke
    Jul 2011
    liverpool
    Default smoke
    Please help car starts great then a bit of grey smoke appears then goes after a bit then comes back sometimes when driving black soot around the exhaust any ideas guys 1.9 diesel sri 150
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Moved to a relevant section as "Problems with the forum and registering" is not the correct place..
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    he probably wont be able to reply to his own post due to 'user awaiting email confirmation' but you are quite correct though....
    So hurry hbomb get yourself sorted
    the paragraph below has been lifted from a web resource about white/grey smoke..
    Low injector opening pressure.
    Incorrect valve timing.
    Incorrect injection pump timing.
    Low cylinder compression pressure.
    Restricted air intake.
    Low turbocharger boost pressure due to worn turbo / intake system fault / boost control.
    Water entering combustion chambers due to head gasket failure, cylinder head or block cracked.
    Jul 2011
    liverpool
    thanks guys something about boost hoses and egr sensor needs cleaning if so where is the sensor and can u just take it out and clean it
  1. Replies: 18
    Last Post: 20th November 2012, 21:41
  2. How much smoke?
    By JonnyB_UK in forum Y & Z30DT Specific
    Last Post: 11th April 2012, 21:25
  3. smoke
    By ryanhamil in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2009, 11:19
  4. smoke
    By scoobyman in forum Diesel Engine related
    Last Post: 22nd August 2008, 10:51
  5. Smoke
    By JCB in forum Parts for sale
    Last Post: 21st September 2005, 13:35
