Thread: Check safeguard keeps coming on display
    Nov 2010
    Essex
    Default Check safeguard keeps coming on display
    I've now got my vectra GSi back from expensive ecu & cim module replacement as before I put the car in for repair the display was saying check safeguard - I was told the immobiliser had burnt the ecu out.
    I've had the car back a few weeks and its started saying check safeguard again!!!
    I'm not sure what to do now, whether to replace the immobiliser with an aftermarket brand like Toad or Cobra or to give Vauxhall another chance to sort it? Car was repaired at Underwoods in Tiptree.
    Engine : 1.9 CDTi
    Get the alarm codes read so you know whats at fault.
    Mine turned out to be a blown fuse.
    Nov 2010
    Essex
    Never going to Blunderwoods again, they wanted £45 plus whatever it was for repairing the fault so I left quickly, they reset it and as soon as jumped in the car check safeguard came on again.
    And that was after I spent nearly £700 on new ecu and cim module...
    Basically I've lost patience with them, Hornet alarm and immobiliser will be replacing the one on the car end of this month...
    Engine : 1.9 CDTi
    If your down Portsmouth way (Or put a post up asking for codes to be read) give me a shout and I will read the codes for you.
  1. Safeguard check
    By VikingLammy in forum Electrical & ICE (including SatNav)
    Last Post: 17th December 2012, 21:39
  2. Safeguard Check.
    By Saxman in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2012, 17:43
  3. "Check Safeguard" on Display
    By BigMan in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2012, 21:07
  4. check safeguard ?????
    By tolly in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2012, 10:59
  5. check safeguard.
    By dansri in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2010, 18:47
vectra safeguard reset
resetting safeguard on vectra
vectra c cim module repair
my vectra says safeguarde
vauxhall vectra safeguard on display
vectra safeguard essex
