Thread: 10k boost
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    Default 10k boost
    gonna do my dads mazda 323 2.0 , 53 plate diesel tomorow , but im not sure if it has a maf sensor or not?
    it says on the tin if it has a turbo , to spray it into there ? however not sure where the turbo is , also it also says if its it does not have a turbo , remove air filter and squirt into the air intake,
    could it be sprayed into the air intake with the air removed even though it has a turbo ?
    dont wanna brick me dads car
    Feb 2006
    north east
    bump
    Aug 2010
    Stoke on Trent
    spray into the air intake but after the maf sensor... do not spray it over the maf...
    West
    best bet is to undo the intercooler pipe nearest the inlet manifold after the turbo
  1. No Boost/Irregular Boost
    By Seery_SRI in forum Engine & Drivetrain
    Last Post: 8th March 2011, 08:48
  2. boost flat spot boost????
    By lgtuk in forum Engine & Drivetrain
    Last Post: 7th June 2010, 16:14
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. no power off boost then savage boost at 2300rpm
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 00:21
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
