Thread: 1.9 cdti with fuel problem
    May 2011
    Norfolk
    Default 1.9 cdti with fuel problem
    Hello and help. I have a 150bhp 1.9 cdti 2006 vectra sri with some issues and am looking for some help!
    First the car will not rev past 3500 rpm there is no turbo spool up, the spanner light came on and has now gone off but the engine management light is on and is in limp mode. The car has been to the garage and it came back with these codes.
    P0400 egr circuit insufficient flow detected. I have now cleaned the egr from the how 2 guide very useful
    P0380 glow device circuit general error
    P0088 fuel rail Pressure High. I have replaced the fuel rail sensor and had the injectors reconditioned 2 had bad back fill
    P0001 fuel metering solinoid valve, fuel volume regulator control circuit open. I have no idea what this is referring to. I think it is on the back of the pump but what ohms should it be reading.
    The car takes 5-7 turns to start it has had full service including fuel filter and I have cleaned the boost sensor.
    If anybody out there can shed some light on this before I loose more hair many thanks
    Jun 2011
    Elland
    Y161 fuel metering solenoid valve - according to a wiring diagram on TIS2000. Can't describe the location, but it does seem accessible - a little to the right of the EGR valve. I can send you a screenshot if you mail me hebblemarine@yahoo.com
    An 'open circuit' could just be a dodgy connector... if you're lucky!!
    From the program:
    • Ignition OFF
    • Disconnect wiring harness connector from:
      Y161 Solenoid Valve - Fuel Metering
    • Ignition ON
    • Measure voltage between the following terminals:
      Wiring harness connector (wiring harness side) terminal 1
      Ground
    Nominal value: greater than 11V
    This check is for 'interuption of voltage supply circuit'
    Can't really offer any more than this, as I'm just reading it off the software, but hopefully it's of some use!
    Regular Member benny's Avatar
    Feb 2006
    dudley
    egr is egr ..glow plugs is glow plugs . the fuel presh ones may be due to a blocked fuel filter ......
    May 2011
    Norfolk
    thanks for the info have sent you an email for the screenshot will check this on wednesday and have changed the fuel filter
    Jun 2011
    Elland
    YGM!
  1. CDTi SRi fuel gauge problem
    By Ade7 in forum Engine & Drivetrain
    Last Post: 8th July 2010, 17:28
  2. Cdti 150 fuel/inlet problem
    By kevcdti in forum Engine & Drivetrain
    Last Post: 17th June 2010, 11:10
  3. vectra 1.9 cdti auto fuel consumption problem
    By stew1501 in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2010, 09:21
  4. 1.9 CDTi (Auto) Gearbox judder and fuel problem!
    By Vectra Singh in forum Engine & Drivetrain
    Last Post: 1st January 2008, 19:24
  5. CDTI Fuel Pump problem
    By bennyk in forum Engine & Drivetrain
    Last Post: 13th July 2007, 16:59
p0088 vauxhall
vauxhall insignia fault code p0088
p0001-02 fuel metering solenoid 150 sri vectra
vauxhall p0088
insignia cdti p0088
astra 1.9 cdti fuel metering solenoid valve location
astra 1.9cdti fuel metering solenoid
vauxhall astra sri 150 cdti regulator control solenoid
fuel volume regulator position on a vectra
y19dth vectra fuel metering solenoid
insignia p0088
p0088 opel insignia
VAUXHALL 1.9 CDTI P0088
Y161 Solenoid Valve position on Opel zafira
Y161 Solenoid Valve Opel zafira
vauxhall vectra p0088
vectra 1.9 cdti fuel volume regulator
vectra fault code p0088
vectra p0088
p0088 vauxhall insignia diesel
p0001 vectra erro code
