Thread: rev limit!
    Feb 2011
    hampshire
    Default rev limit!
    hello does anybody know what this could be? i was in 3 rd gear doing around 4 thousand revs and seemed to hit my rev limiter! its not a diesel then the spanner light came on, every other gear seems quite happy to rev higher thanks ps its a 2.2 petrol
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    if its th 2.2 direct mines the same seems to be a bit of a flat spot for some reason : anyone help?
    Jun 2011
    blaydon on tyne
    mine was doing the rev limit thing when the fuel pump was playing up but this got worse very quickly and was terrible to drive, not just a one gear thing.
    Feb 2011
    hampshire
    thanks for the replys, it is a 2.2 direct, did the spanner light come on?
    Feb 2011
    Selby
    4000rpm limit comes in for a variety of engine sensor faults - cam or crank sensor are the most common.
    I've spent a few weeks sorting out a cam sensor fault - the symptoms being that it'd about 2 out of 3 times you start the engine, it'd drive perfectly normally but won't go over 4000rpm. Turn the engine off and restart it, and it goes back to normal operation, revving over 4000rpm.
    If you disconnect the battery for a bit, or use an OBDII reader to blank the fault code, then it will put on the engine fault light when the fault next occurs. However, after about 3 or 4 starts, it will turn off the light and not put it on again, but the rev limit is still there.
    Get your fault codes read (easy on a 1.8, just hold down brake an accelerator and turn ignition on, but that doesn't seem to work for the other engines), and hopefully it'll be an easy fix.
    Feb 2011
    hampshire
    thanks rich r
  1. Knowing your limit
    By spoons in forum General Chat
    Last Post: 7th August 2009, 12:53
  2. Paypal Gift Limit?
    By JSYSH466Y in forum General Chat
    Last Post: 21st June 2009, 00:26
  3. Speed limit question
    By adfrodsham in forum General Chat
    Last Post: 14th April 2009, 08:48
  4. New speed Limit of 78MPH
    By AJA in forum General Chat
    Last Post: 26th January 2007, 17:08
