Thread: fuel filter change gone wrong please help
    South Wales
    Default fuel filter change gone wrong please help
    Changing fuel filter on my 2003 2.2sri and the actual pipe snapped instead of the clip coming out, its the pipe from the filter to pump end, i have put some pics in please guys can you help??? Can this be fixed, how much and how really, this car is a money pit at the moment, going so wrong, advice would be so much appreciated. I will log back in later as I have to clean up the petrol over the carpark outside the house
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    without replacing the whole length it may be easier to go to a scrappy and cut a section off a vec then join it to your remaining pipe
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    South Wales
    does anyone know how much the new length would be and how difficult it is to fit?? If I could get a good joint i would do it but not sure i trust my joining skills
    Regular Member benny's Avatar
    Feb 2006
    dudley
    needs a "new" complete pipe ...weather its new or used you cannot cut it and need the whole length from where on the tank it fits ....
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    Did you apply some, "brute force and ignorance" to remove that filter, that was probably fine btw?
    N
    I've just had a similar incident happen to me, but instead the plastic female socket part was broken (part in red, hope stubopvectra doesnt mind me using his pic):
    Can you buy the connector seperatly or do you have to buy the whole cable? If so, how easy is it to connect to the fuel tank? Do I have to lower the tank or remove anything to get access?
    Any help would be hugely appreciated!
    N
    Just in case its of any use to anyone....
    Yes you do need a new cable fitted if only the socket part is damaged, as its all one piece! Fitting does also require the tank to be lowered! So be carefull changing that fuel filer!
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Thought i'd reuse this thread as I have the same problem as yoclick above.
    Does anyone have the part number for the pipe above?
    Many thanks
    Jim
    north east
    for now just jubalee the pipe ont ot eh new filter, then go down vaux they sell this section "filter section" seperatly ... almost as if they knew it would break
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Tried the jubilee clip fix but the pipe is smaller than the filter end so it wouldnt fit. so, I disconnected the pipe from under the rear bench and and pulled up the pipe, took the part number from it and ordered a new one from the stealers £18.80 inc. VAT (might see if I get discount for trade club).
    For future reference the part number is : 24403456. This pipe goes from the fuel pump to the fuel filter.
    Regards
    Jim
  1. 2.2 dti fuel filter change
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2012, 08:57
  2. Fuel filter change?
    By parky1 in forum Engine & Drivetrain
    Last Post: 13th August 2011, 22:24
  3. fuel filter change vec c 2.0t
    By johnturbo in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 19:36
  4. fuel filter What have i done wrong
    By forkieman in forum Diesel Engine related
    Last Post: 4th March 2009, 12:40
  5. 1.9 Fuel filter change
    By Keith Jones in forum Engine & Drivetrain
    Last Post: 11th October 2008, 21:11
