Results 1 to 10 of 13
Thread: 215/50/17 Tyre pressures
    Regular Member ian1401's Avatar
    May 2011
    Exeter
    Default 215/50/17 Tyre pressures
    i,m a bit confused,the owners manual says 32 psi and a online site says 41psi, which is the right pressure,i checked my tyre pressures yesterday and they were at 40 psi
    Regular Member themarbleman's Avatar
    sussex
    My 3.0 V6cdti runs at 41 up front and 38 in the rears...
    Big heavy engine...Lol
    Hope this helps you but other size engines will be differant
    May 2011
    Exeter
    thanks for relply..do i use the handbooks fiqures or leave them as they are?
    Use the handbook figures.
    The pressures for a 2.2 petrol are 32psi all round for a load of up to 3 people.
    I run mine at that pressure regardless whether just me, or if I have a full load. No abnormal tyre wear in the 4 years I've had it.
    Quote Originally Posted by ian1401 View Post
    Which website was that?
    I have the same issue with some websites, they come up with incorrect tyre pressures (and sizes)
    As above, go with the handbook
    Quote Originally Posted by themarbleman View Post
    That's a tad high unless you have other wheels on or it is an estate (for a 3.0 V6 CDTI up to 2006)
    On the 215/50R17 they should be 38 front and 35 rear
    On the 225/45R17 they should be 39 front and 35 rear
    May 2011
    Exeter
    the website was http://www.tyreshopper.co.uk
    thanks for the replies..
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    For maximum economy the handbook quotes 35 front and 35 back for up to 3 people.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    12 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Sorry to hijack ....Whats the pressures on 225/45/17's on a 2t?..
    Quote Originally Posted by nikroc View Post
    The same as the 215/50/17 size.
    33 psi all round for a load of up to 3 people.
    35 (f) & 42 (r) for a full load.
    Quote Originally Posted by paulhb View Post
    My handbook quotes 36 psi all round for the eco setting.
  1. Tyre pressures
    By Chewy72 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2012, 01:00
  2. Eco tyre pressures
    By Mike57 in forum Handling & Braking
    Last Post: 29th February 2012, 14:31
  3. Tyre Pressures
    By Tango in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2009, 00:10
  4. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  5. Tyre Pressures
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2006, 00:49
21550r17 95w tyre pressure
215 50 r17 tyre pressure
215 50 17 tyre pressure
21550r17 tyre pressure
vauxhall vectra c tyre pressure
215 50r17 pressure
215 50r17 tire pressure
21550w17 tyre pressure
2155017 vectra c estate
tyre pressure for 215 50 17
vectra c 17 tyre pressure
air pressure for 21550r17
21550r17 psi
vectra c estate tyre pressures
vectra 215 50 17 tyre pressure
whats the best tyre pressure for 21550r17
vectra c elite 2155017 tyre pressure
21550z17w tyre pressure
215 50 17 vectra c pressure
tire pressure 21550r17
whats the correct psi for a 22545r17 tyre on a vectra c
vectra c 2155017 tyre pressure
vectra c 1.9 cdti 2155017 tyre pressure
