Thread: What cars is this used on (Part number)
    Engine : 1.9 CDTi
    Default What cars is this used on (Part number)
    I need to replace one of the Signum number plate light holders conectors.
    This is the item:
    And how it looks out of the panel:
    Not sure which one is the correct part number but it has 22431700 and 464192822 on it.
    Jun 2011
    brum
    you may want to wait for someone knowledgableto help you. But i'd say from a quick google search it would be the top one. The 464... number returns front grills and even wheels. but the 224 number returns nothing. Since its a pretty inconspicuous part, most people probably wouldnt post the part numbers about as they'd probably be selling that thing as a larger unit (i.e. full assembly). Hence why google dont return anything useful on it.
    So in conclusion of all my ramblings, those codes look as if their saying part 224 fits into larger part of 464 ?
    Probably not useful at all, but i thought id try :P
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    EPC4 gives:
    90213642 - Lamp Assy, Rear Number Plate - appears to be the bit that actually hold the bulb.
    24431700 - Plate, Contact, Rear Number Plate Lamp, Tail Gate Handle - looks like the part with the long clippy legs and the numbers, you have to sat to the right.
    Numbers double checked - 22431700 comes back as not known, so may be an old number, moulding error or EPC error but either way that is the number for the part you have removed.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Confirmed as above.
    Engine : 1.9 CDTi
    Item 14 is what needs replacing as one of the platic bits inside that the copper contacts are against is broken so there is no tension against it.
    Depending on cost might be worth replacing both and the lenses too.
    Is it just the Signum they are used on?
    Thanks guys
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by lee gsi View Post
    Thanks guys
    As far as I know it's just for the Signum yes. Won't be that expensive.
  1. CID part number
    By dholbon in forum Electrical & ICE (including SatNav)
    Last Post: 17th August 2011, 13:24
  2. Part number?
    By rioni in forum Engine & Drivetrain
    Last Post: 13th August 2011, 14:26
  3. Part number help
    By Lee_gsi in forum General Chat
    Last Post: 10th August 2011, 20:26
  4. Part Number help
    By EARLEY in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2008, 01:40
