Thread: Signum rear wash squirty not working
    Engine : 1.9 CDTi
    Default Signum rear wash squirty not working
    Had the car in bits today trying to find out why the water squirty didnt work on the rear of my Signum (Never has since I bought it).
    Started off by pulling the rear hose of the high level brake light washers and tried the pump but nothing came out.
    Then pulled off the 2 pipes from the washer motor and tried the pump again. This time water squirted out of both pipes coming out the motor itself.
    So I now knew it was a blocked pipe somewhere. Started at the front of the car and worked my way along the pipe looking for a crushed pipe or something (I had no water in the car so knew it wasn't a holed pipe). No crushed pipe all the way upto where it goes in the rear quarter.
    Pulled the pipe out of there to find a join that was infact a oneway valve. The oneway valve is just a bit of rubber that opens when water is pressurised at it (Pump running) but closes when there is no pressure (Stops the water running all the way back). My oneway valve had somehow managed to roll itself up and block it solid. I pused out the rubber valve/blockage but the rubber valve had a split in it so I have left it out for now.
    So for anyone else with a rear water squirty that doesn't work but the motor works and the washer jet is clear that may also be the problem.
    Water pipe at high level brake light:
    Join/oneway valve in the nearside rear quarter behind panel:
    And a close up of where it is:
    And the oneway valve with the rubber/valve pushed out:
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Nice bit of info there mate, handy knowledge to save a few hours painful fault finding
    Engine : 1.9 CDTi
    Thats why I posted it up.
    Save someone else ripping there car apart as its so much quicker/esier when you know where items live
    Bordon, Hampshire
    Clever design too... did wonder why I have never had to wait for the washer water to feed up the pipe even when the car has been sat... now I know
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    So is it working now fella?
    Engine : 1.9 CDTi
    Yeah all sorted.
    With the rubber bit removed it pumps for about 2 seconds before the water comes out.
    Regular Member matt.d's Avatar
    May 2011
    gravesend
    Vehicle : vectra c
    Trim : breeze
    Engine : 1.8 16v petrol
    got the same problem with my vectra c nothing comes out the back it would be excellent for pictures on this one
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Great heads up on this, mine was poor to say the least. Ten minutes later both jets working fine.
    Cheers!
    Sep 2013
    Norfolk
    Vehicle : Elegance 16v Auto
    Trim : 5 dr hatchback
    Engine : Z22 SE
    Mileage : 60,000
    Thank you for this post, Lee; and your further help in pm's. My valve (03 Vectra hatchback) was in the roof lining and a real pig to get at, but were it not for your post I doubt I would have ever resolved the loss of rear wash! The grommet had got itself completely inside the narrow bore of the valve housing.
    Like you I have chosen to leave it out now, but in any event, given the direction of flow I cannot figure out where it should sit to act as a non-return?
    Mar 2012
    Cardiff
    Trim : Elegance
    Engine : 2.2 Petrol
    Hi,
    I am new to the forum and I have the exact same problem with my Signum ... no water from
    the rear washer jets.
    The photos are really great ... however can you tell me what parts I need to remove to
    get to it?
    It looks like it needs to be the left side of the parcel shelf (or whatever it's call)
    and the left panel ... anything else?
    Thanks in advance.
    Simon.
  1. Signum rear water squirty not working?
    By lee gsi in forum Bodywork & Interior
    Last Post: 29th September 2010, 21:10
  2. rear wash not working
    By mel in forum Bodywork & Interior
    Last Post: 6th April 2010, 13:24
  3. rear wash under aerial
    By vectragsi3.2 in forum Bodywork & Interior
    Last Post: 23rd August 2008, 18:02
  4. Rear Wash Wiper Sprayer
    By David_SRi_2.2DTi in forum Bodywork & Interior
    Last Post: 23rd July 2007, 10:39
  5. Windscreen Squirty Check Light ?
    By Bainie in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2005, 21:25
