Results 1 to 10 of 21
Thread: Z19DT valve clearances
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Default Z19DT valve clearances
    Hi
    Anyone have the clearances ?
    In: ?
    Ex: ?
    Thanks in advance.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    They not running off hydraulic tappets and Self adjusting?
    May 2011
    lancs
    It's in the haynes manual regarding valve clearances, Says theres a shim with clearances stamped on them and then you use a micrometer if shims have worn you can get new ones then alot of adding and substracting to workout getting correct shim, Something along them lines i just turned the page lol
    If needed pm me your email addy and i'll try and scan the page and email it you
    Bristol
    All ne 1.9 @ 30 are Hydraulic but are also shimmed. If they are noise then you will have to get ne shims there must be a engine reconditioner that my do a swap sysrem I don't know but its worth a look and also look at new shim prices wten you have the correct clearances.
    Bordon, Hampshire
    Ahhh okay good idea that adding in shims to take up the freeplay! I like...!
    May 2011
    South London
    Hi
    Yes I have done this job many times on other shimmed heads.
    Sometimes you can swap them around but usually you need approx 4-5 new ones.
    I just need the clearances if some ones got a Haynes manual could you post them please.
    Inlet..........
    Exhaust..........
    Many thanks.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    i have no idea on the data but you can do them with only takeing the rocker cover off use a pry bar to push the valve down and then pull the shim out ..much like tha old isuzu stuff ...
    May 2011
    lancs
    The haynes states z19dt valve clearances for inlet and outlet are 0.30 to 0.40mm and specify vx special tool En-46797 and En-46799 or equivelant if adjustment is needed, Hope this helps and below is how you work out what shim is required.
    Add the measured clearance of the valve to the original shim then substract the specified valve clearance from this figure. This gives you the thickness of the shim required: For Example Below
    measured valve clearance 0.45mm
    plus thickness of the original shim 2.70mm
    equals 3.15mm
    minus clearance required 0.35mm
    thickness of shim required 2.80mm
    May 2011
    South London
    Hi
    Thanks for the info tommytonguedj
    In : 0.30-0.40
    Ex: 0.30-0.40
    I have a few of these shims , you can bet none of them will be the right size though
    As for the tools...... my special screwdriver (long wide bladed one) and long nose pliers
    have always been my choice of weapon doing this job (sometimes my telescopic magnet also for stubborn shims)
    May 2011
    South London
    Found the problem
    Cyl No 2 Ex cam lobe worn .
    All other clearances ok this one was 0.55 at the bottom, with a pointy cam lobe
    The hardening's gone completely
  1. Z19DT EML Help...
    By Vectra Adz in forum Engine & Drivetrain
    Last Post: 19th November 2012, 23:10
  2. Checking Valve Clearances - 1.9CDTI (Z19DT - 120)
    By snapsnap in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd January 2012, 09:41
  3. Z19DT OP-COM readout
    By Astra H in forum Engine & Drivetrain
    Last Post: 30th April 2011, 13:28
  4. Z19DT vacuum.what is this?
    By tox in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 15:50
  5. New 1.9CDTI DMF Z19DT - £100
    By danBoy in forum Parts for sale
    Last Post: 7th January 2009, 19:39
opel z19dt valve shimming
tappets adjustment z19dt engine
z19dt engine swap
astra 1.9 cdti tappet adjustment
