Thread: brake squeel
    Jun 2011
    brum
    Default brake squeel
    Ive got some squeeling from the brake pads (i imagine). Think its the front passenger but you never can tell. Its worst when i get someone else in the car, it often goes away if i push the brake pedal in a couple of mm. but then squells again as it actually slows the car down.
    Im not sure if my car has a low brake pad sensor or not (no lights coming on, on the dash anyway). I heard that they stick tags on the pads now so they purposly make noise when running low.
    but ive also heard that the disc could be warped or the horror stories of bearing problems.
    Im gonna check my pads today. Im guessing i can just look/feel for um through the wheels. But is there anything else i need to be aware of or can look for in regards to finding the problem.
    Its been happening for about a week so i'm guessing its not just crap or water on the pads.
    Aug 2010
    Leeds
    Calm down old lad.
    Brake pads squeel either due to heavy braking and the friction material glazes over & to stop it you can rub the surface down with emery cloth but if heavy glazed just replace the pads.
    Or they squeek in the brake pad carrier the part the pads sit in, so remove and clean up with a wire brush and put a little copperslip on the parts were the pad sits in the carrier and on the back of the pad.
    Usually fronts should last 35-40k easily but we all drive differently.
    Same for rears but have heard these don't last quite as long.
    Jun 2011
    brum
    i'll have to check um. the car was serviced quite regularly before i had it so im guessing the pads thickness should be ok if they last so long.
    i remember reading about the pads moving about. I'll have to get the wheels off when the work over the road closes so i can use their car park area. i got me some copper slip lying around somewhere i think. What classes as light and heavy glazing? i'm still picking the diy mechanics up as i go so ive never come across that
    Aug 2010
    Leeds
    It's very shiney and can have surface cracks in the pad, also check the bonding on the rear of pad to metal backing is not coming away from the heat, do this with a wire brush up.
    If your totally unsure just replace the pads and possibly the discs if totally shot but these can be re ground the outside lip off if within wear spec.
    What is the mileage?
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    One note on the copper slip... go for ceramic brake paste as I was advised some years ago to stop using copper slip on cars after 2001 due to new brake components being made of aluminium/plastic etc and other materials that can react and corode with the old stuff
    Aug 2010
    Leeds
    Which parts in the cars braking system on the vectra has this? New one not noticed any.
    Bordon, Hampshire
    I didn't specify on any particular model, I just advised, as I was advised to used ceramic paste on vehicles after 2001...
    Does it matter which vehicles should use which type? Or seeing as they do the same job, is it good practise to just go with the ceramic paste so you don't caught out down the line when you upgrade your car and use the left overs of the copper slip you have lying in the shed...
    Jun 2011
    brum
    mileage is 96000 miles. I also just realised the front of the service history print off has a different reg plate code to the back of it. So based on that, im guessing the back of the print off only applies to my car. Which means it was serviced at 18k, 40k and 60k
    Cant see anything on there relating to brake pads so im guessing unless there done as standard under the service, they may have never been changed
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    would also check the backing plate behind the disk to make sure its not touching the disk, i had the same problem a while back and turned out to be the plate just toucing the disk and no more. but the sound went away when i touch the pedel.
    Jun 2011
    brum
    im gonna get the wheels off tomorrow. starting with the front passenger since i think thats the side its coming from. I'll have a google for this backing plate thing, since ive never really seen the brake system i dont know what your talking about. but i'll try and bear it in mind as a thing to look for when i get the wheel off. Thanks
  2. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  3. 1.9cdti 150, DMF & CRB Squeel
    By barkzz in forum Engine & Drivetrain
    Last Post: 22nd July 2011, 11:30
  4. Wheel squeel
    By Tigger in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2010, 21:29
  5. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
