Thread: changing the clock
    VECTRA1974*
    Guest
    Exclamation changing the clock
    hi guys,is there anyway to change the clock after you have changed your stereo unit,mines is still in 2008 the day it was made,
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    RTFM, or try the little buttons under the display, a long press on 1 of them should start the setting facility.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by kentish_bloke View Post
    RTF original post
    If you've changed the stereo then you'll have to put the original back in to change the clock
    VECTRA1974*
    Guest
    no buttons under mine,had the cd 50,but got a double din fitted ,ill just leave it then
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    my mate changed mine with a certain computer program and laptop
    Oct 2006
    southampton
    15 Post(s)
    Quote Originally Posted by TimTay View Post
    Hmmmmmmm same here, right, if you have a tid and steering controls you can do it from the buttons on the steering wheel, if its GID or CID then software or original HU...
    VECTRA1974*
    Guest
    im going to have a look,need to get it done fed up with seeing 2008
    Regular Member coldo's Avatar
    Scotland
    assuming the CD50 and CID or GID displays are the same as the Astra then there is three possible ways for you to change the time on your clock.
    1. put the old radio back in to change time and then sweap back the new unit. I discovered that one my H i managed to put the ISO plug next tot he glove box so by qyuickly removing this i could plug the old radion in here and not takle out my new head unit etc.
    2. The connect2 leads offer an option to let you access the BC through the stearing wheel. I have never tried this myself but apparently it is all possible.
    3. Buy opcom. You canchange the time date etc using this and lots more on top of it if you learn how to use the thing.
    Hope this helps
    C
    Full Member
    South West
    What i did when i had an aftermarket HU was pop up to my local Vx dealer, and very politely ask if they would mind changing the time/date on my display.
    They did mine right there and then with no charge. Gotta be worth asking mate.. They can only say no unless you cough up some cash! If you dont ask, you dont get!!
    Rgds
    Aidi
    Aug 2009
    Wakefield
    i can confirm that the connects2 loom allows access to all BC functions, much better than autoleads version in this respect.
    see link below for more info:
    http://www.connects2.co.uk/Instructions/SVX002.PDF
  1. Changing the clock time
    By bensterzback in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2013, 10:18
  2. Changing time on clock without standard sterio in
    By shearzy in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2010, 21:42
  3. Changing clock
    By jrh1 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd October 2009, 12:07
  4. Changing clock lights
    By andy_higgy666 in forum Styling
    Last Post: 28th February 2008, 20:12
  5. changing clock lights
    Last Post: 28th February 2008, 03:10
