Results 1 to 10 of 16
Thread: can you please help me with a starting problem on a movano 2.2 DTI
    Jun 2011
    weling kent
    Default can you please help me with a starting problem on a movano 2.2 DTI
    Hi to you all
    Can you please help me
    ive had a new timing belt and pulleys fitted but since then my van well only start with e/start.
    I locked the cams up with the timing lock tool, but on the crack i remove the bolt to lock it up, but each time I find a hole to lock it up it was the wrong hole (4 holes later) still no good.
    I then remove no 1 injector to get TDC, put it all back together still didnít start so I tried e/start and it start , I drive it and let it tick over for apex 30 mins, turned it off would not start again it just spin over and over.
    Tried e/start it started first time, turned it off NO START
    So at the moment it starts first time but only with e/start
    Glow plugs and relays are all working fine
    Crankshaft and camshaft sensors was renewed apex 5 months ok
    SO CAN ANY ONE HELP ME
    many thanks chris
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Might be worth asking some Renault mechanics too as this is a Renault engine I think
    Jun 2011
    weling kent
    thanks for your reply ill done that
    thanks chris
    Jan 2010
    glasgow
    hi mate is there 4 holes it may be like the 2.5dci with markings on the pully you will have to give it a good clean to see them it may say
    1. RENAULT
    2. DAYCO
    3. PMH
    4. A diamond shape with 167 stamped in it
    5. There are also 4 holes drilled in the periphery
    pmh is french for top dead center dont know if its the same tdc setting on the 2.2dti but, are you sure its pulling fuel up?
    Jan 2010
    glasgow
    ps mate i think the movano engines have 2 different pump timing positions, thats why im asking are you sure you have timed it correct for your engine
    lincolnshire
    if it was fine before the belt change then it stands to reason that the timing is out
    Jun 2011
    weling kent
    Quote Originally Posted by hoochydady View Post
    1. RENAULT
    2. DAYCO
    3. PMH
    hi
    on the pulley theses no mark or writting at all totally clean
    deisel is up fine straight away on all 4 injectors
    before it started first time didnt have to wait for glow plug all
    Jun 2011
    weling kent
    Quote Originally Posted by bembo449 View Post
    hi
    have you got any idea how i can check
    ive had 1no injector to get TDC, on the crack pulley theres no marks at all
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Are you getting fuel to the injectors when its not starting? Or just when you tested before it started originally?
    Bordon, Hampshire
    Thought the Movano would of been running with a fuel rail and electronic injectors??? As opposed to a fuel pump that may be affected cylinder timing etc
  1. HELP, starting problem
    By ChrisChristopher13 in forum Engine & Drivetrain
    Last Post: 9th April 2012, 08:38
  2. can you please help me with a starting problem on a movano 2.2 DTI
    Last Post: 16th July 2011, 22:53
  3. Starting problem
    By trace in forum Insignia car chat
    Last Post: 7th April 2010, 07:18
  4. Problem...? Vectra SXI...problem with starting after filling with fuel?
  5. starting problem
    By chunkster in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2008, 13:09
