Results 1 to 2 of 2
Thread: Fitting replacement engine tech2 ecu programming??
    May 2011
    lancs
    Default Fitting replacement engine tech2 ecu programming??
    Hi All, The stage i'm at with my blown turbo is whether just to throw another engine in my cdti120 i can source one around the same price as what it's gonna cost me to replace the turbo with 60000 less miles on the clock, My question is will the replacement engine need programming to the car and and will i need the ecu off the donor car too. Big Big Thanks In Advance
    May 2011
    lancs
    Definately gonna need an engine just checked the throttle body and there were bits of metal in it and the pipe leading to it from the intercooler has all tiny bits of metal in it, also found a couple that were a few mm big right near throttle body entrance which aint good.. Can't believe this thought diesels were the way to go, Anyone a rough idea how much mechanics are charging nowadays to remove and fit an engine that i supply. with all the service/parts history i have with car and this it totals to a massive amount for a 6 1/2 year old car, i'm putting my mondeo mk3 back on the road i've owned that since brand new it's never had anything wrong with it apart from needing a cat in 8 years apart fromobvious service parts
  1. UHP4 BT TECH2 programming
    By msqualo in forum Electrical & ICE (including SatNav)
    Last Post: 19th September 2016, 23:22
  2. CIM Replacement - Programming
    By any-mgzt in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2013, 14:34
  3. help with tech2 programming auto AFL
    By emsedk in forum Electrical & ICE (including SatNav)
    Last Post: 18th September 2012, 16:54
  4. Tech2 Programming.
    By Adam B in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2010, 20:55
  5. Need help 4 TECH2 Programming
    Last Post: 24th May 2010, 20:51
