Thread: Lumpy Engine
    Regular Member thefibreguy's Avatar
    bedford
    Default Lumpy Engine
    Guys, Have had a problem for a while now, the engine, cold, or hot, gives intermittent very lumpy idle.
    Car is an AUTO estate 1.9cdti 150
    Just had the cambelt/waterpump done by local mechanic, & when I showed him the problem, he thinks is a loose flywheel. gave me a guesstimate of approx £500 inclusive of parts.
    Anyone come across this on an AUTO?
    Regards,
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    mines a manual, do you mean as though its rough or uneaven on tickover but not as though its the engine as sutch, more like an in-balance?. mine does this sometimes hot or cold but not all the time, i was thinking or knowing really it maybe the flywheel cos it has the slight rattle of death sometimes aswell.
    bedford
    Hi, I dont think its the engine, I do think its a balance thing. the only thing that gets me is that its intermittent, the mechanic said this was probably due to the metal expansion/contraction etc. He is quite a clued up guy, so will just let him get on with it!!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    When it happens next watch the exhaust tail pipe to seen if you get any puffs of blue smoke.
    Apr 2011
    Matlock
    have you had the EGR valve checked??
    Bucharest Romania
    I had your problem on my 05 z19dth manual , everyone said it is the fly wheel,so i changed the whole clutch assy. but my problem just got a little better but did not go away. ( this was due to the new flywheel wich was better than the old one).
    the problem was my crack- pulley , witch was in one piece. the only difference between the new and old was, that when droped from ~2 feet on the ground the old one had a mettal rattle the new one sounded solid.
    hope that helps
    just take out the pulley and dropp it on its side and listen to the sound.
  1. My engine is more lumpy than my mrs cooking !!!
    By cyberbobdude in forum Engine & Drivetrain
    Last Post: 25th August 2012, 17:15
  2. Lumpy engine then limp mode
    By themarbleman in forum Y & Z30DT Specific
    Last Post: 1st August 2012, 20:17
  3. Engine lumpy now Engine Management Light is on
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 16:51
  4. Lumpy engine at low revs, when warm., help.
    By super sleuth in forum Engine & Drivetrain
    Last Post: 28th July 2011, 20:32
  5. Replies: 13
    Last Post: 20th May 2010, 20:09
