Thread: rear bearings
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default rear bearings
    I've waited until the rear tyres needed changing until i decided the explore the annoying droning...
    Tyres changed and noise still present so its time to look at the wheel bearings. No obvious play and £60 each hub/bearing setup..
    How do you test em further..and any ideas as to how you change em?...
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi nikroc
    try spinning wheels with car jacked up see if you can here anything,it dosen't take much play to cause a bearing noise.
    it's a fairly easy job to change bearings,remove wheel ,brake calliper (support calliper don't let it hang on the flexy hose)remove the 4 nuts from the rear of the hub(you will need socket,extension,and a universal joint as one nut is a bit awkward)remove hub and refit with the new studs provided,about 60 to 90 mins per side.
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Appreciated Mr Bravo..will take a listen on the moro
    Jul 2009
    Engine : 20 Dti
    as said straight forward just a bit akward,nothing to worry about,if you get stuck PM me
  1. For Sale: Sri clocks, leather door cards, rear e/windows, wheel bearings
    By krazylegz in forum Parts for sale
    Last Post: 6th November 2012, 07:13
  2. rear wheel bearings
    By stickygreen in forum Suspension, Wheels & Brakes
    Last Post: 27th September 2011, 20:19
  3. Rear Wheel Bearings
    By mathewjcooper in forum Suspension, Wheels & Brakes
    Last Post: 7th August 2009, 21:40
  4. Rear bearings?
    By rhenderson in forum Suspension, Wheels & Brakes
    Last Post: 11th November 2007, 13:18
  5. Rear Wheel Bearings
    By kinger in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2006, 12:51
remove aifnum rear bearinf
