Thread: Clutch Release Spring
    Regular Member PORKBALLS29's Avatar
    Epping
    Default Clutch Release Spring
    Gradually over the last few months I've noticed a loud creaking coming from my clutch pedal, also a very odd feeling as if the biting point kept changing, when you released the pedal to get the biting point it would feel as if it got stuck at a certain point and then it would release.
    So from havng a quick look on here I decided I would change the clutch return spring and see if it made any difference.
    Fitted it last night and WOW what a difference, it feels like a new car. I had started to think that maybe it was just me and my driving style lol.
    I had to break the original spring off as the plastic shaft inside the spring was jammed and it wouldn't compress properly and also the spring its self had stretched at one end so no wonder I was having problems.
    I would recommend this to anyone who's having the same sort of problem. Part No for spring is 93183937 and was about £7 + vat with trade club.
    Pics of the old spring and then the new one as below.
    H
    Full Member spennny's Avatar
    Blantyre
    I cant believe you already had one there mate, i had nothing till i fitted mine last night also along with Brake switch and clutch switch
    WGAF#5
    so it wasnt your brain then .... lol
    i'll give it a miss on mine
    Blantyre
    Its a 2 min job mate
    Hardest part is getting in a position to change it lol,
    Epping
    The hardest bit on mine was getting the original one out, I had to snap the inner shaft as it was stuck. Fitting the new one was a easy.
    Dont all Vec's/Siggy's have these fitted then?
    Regular Member Jezzy's Avatar
    S.E
    Not autos.
    Epping
    Not autos.
    Obviously
    Not autos.
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Same Part Number For My 52 Plate/1.8/LS ???
    Epping
    Quote Originally Posted by Tam80 View Post
    Same part number for all manual models as far as I know Tam.
  1. Clutch Thrust Release Bearing Perhaps.?
    By sootyville in forum Engine & Drivetrain
    Last Post: 24th July 2011, 07:58
  2. clutch release bearing
    By martin_SRI in forum Engine & Drivetrain
    Last Post: 20th December 2010, 21:37
  3. clutch release bearing
    By pizzajazz in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 17:36
  4. Clutch release bearing help 3.2 GSi
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 29th June 2009, 10:52
vectra clutch release spring
