Thread: Help Please car at VX with P0234 - Boost Pressure Control Circuit Negative Deviation
    Regular Member Vectra Forever's Avatar
    Apr 2011
    Somerset
    Default Help Please car at VX with P0234 - Boost Pressure Control Circuit Negative Deviation
    Hi
    Driving into work this morning at at 55mph LHM! Shutdown and restarted to clear the fault and all was ok until I got to work and same again. Drove to VX dealer and got it on diags with the following error.
    P0234 - 5A Boost Pressure Control Circuit Negative Deviation Present.
    I think this is over boost as all the sensors have been replaced not too long ago. VX are saying to get the wastegate actuator rod lengthend to reduce the amount of boost.
    If I get them to do it will it fix the problem?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Just give the boost sensor a clean with some carburettor cleaner , when was the last time you cleaned the inlet manifold
    and still loving it
    Apr 2011
    Somerset
    Quote Originally Posted by bobssignum View Post
    Hi,
    It was done this weekend when the entire inlet manifold was out and a brand new EGR put in
    http://www.vectra-c.com/forum/showth...=140670&page=2
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Have all of the pipes been checked for splits. Lengthening the actualtor is a last resort but it does work
    Apr 2011
    Somerset
    HI,
    Intercooler pipes are brand new all round and vacuum pipe also brand new. I did give them a once over after the rebuild and all seem fine. I have to go to Devon this afternoon to get my Daughter. Its a 120 mile round trip so I have no choice but to lenthen the actuator
    Apr 2011
    Somerset
    Angry It's happened again!!!
    Guys,
    This has happened again, twice in two days both between 1500 and 2500rpm.
    I am going with this as the only possible sensor left in the entire engine bay to change is the MAF. Does anyone have any clear idea if the MAF and boost sensors work together to calculate right ratio's.
    The actuator was adjusted at VX last time to lengthen it which did help but again the fault is back. I've lengthened it another half turn yesterday but had made no difference. I'm now getting concerned that if it gets lengthened anymore, then there will be a lack of boost. I can already feel that it is not as quick and slower on acceleration than before.
    Just to be clear, all sensors except the MAF have been changed in the last 3 months and the boost sensor cleaned last night. All pipes checked inc vacuum which were also changed a month ago. No leaks, breaks nothing.
    Ideas anyone please?
    Regular Member swet's Avatar
    Silistra
    Changing MAF might help you 'cause one friend of mine has suffered the same problem with his Zafira,he went to service where they replaced the MAF with brand new and the problem disappeared.
    Regular Member TonyTM's Avatar
    Timisoara - Romania
    No need to change the MAF. The problem is with the variable geometry of the turbo. It is blocked and therefore it creates too much pressure.
    Try to move the actuator on the turbo and see if it moves. IF it moves then the fault might be with the vacuum turbo solenoid.
  1. Fault Code P0234 - Boost Pressue
    By Gazz in forum Engine & Drivetrain
    Last Post: 15th October 2012, 10:48
  2. error code P0234 - Boost pressure control
    By duncanm in forum Engine & Drivetrain
    Last Post: 4th May 2011, 17:24
  3. Help needed - C0131 ABS Pressure Circuit
    By z32se in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2009, 22:04
  4. Replies: 6
    Last Post: 3rd September 2009, 16:40
  5. P1191 - fuel rail pressure sensor circuit low input
    By L11Marc in forum Engine & Drivetrain
    Last Post: 17th March 2009, 17:12
boost pressure control sensor negative deviation
zafira dti boost control deviation
P0234-5A Boost Pressure Control Circuit Negative Deviation
Vauxhall DTC P0234-5a
p0234 vauxhall
p0234 boost pressure control circuit negative deviation
p0234 boost pressure control positive deviation
