Thread: cdti turbo noise
    Regular Member coooky's Avatar
    May 2011
    washington
    Default cdti turbo noise
    the car sounds like it has a mini dump valve kind of sound foot down normal driving and change gear a sort of slight pishh is this normal never noticed it before
    also never noticed it on all my diesel turbos mondeo ghia,golf tdci,laguna,passat and x-trail
    also the turbo is really loud on the car is this right for a vectra as the above cars i could hardly hear the turbo if at all
    lincolnshire
    could hear this on my 120
    May 2011
    lancs
    mine done this when i bought it cdti120 to be on the safe side for the sake of an hour under the car get the inlet and outlet off the turbo and check the shaft/turbines for play, My turbo's just siezed and don't know whether it's damaged my engine yet so well worth checking every few months, Also been advised to change banjo bolt on turbo every year now which i intend to do when i sort my car out
    does it sound like a distant siren??
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Morning all,
    I get this on my cdti 120, I have checked everything under the bonnet, and had a mechanic look over the car.
    Just to rest my mind at ease, I have had the car hooked up to tech2 and fully serviced (it was due and at 90k anyway) & the turbo checked and all pipes checked.
    Mine sounds the same as described above, although sounds more like actuator chatter, than a dump valve.
    Quite like the sound, but don't believe it's anything to worry about.
    Oct 2010
    London
    Turbo on my 150 is a right loud'n, nothing whiney about it just loud!
    My old 1.7 sounded like a police siren when cold at the right revs, confused the gf a few times haha
    South Central England
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    That sounds like an unresponsive actuator/vacuum control solenoid or sticking VNTs to me. The pishh noise is likely pressure backing up through the turbo and air box. Normally when you dump the clutch or come off the accelerator, the ECU very quickly backs off the turbo. If the turbo is not backing off quick enough, it could cause the this.
    May 2011
    lancs
    Quote Originally Posted by nutron View Post
    Hi Nutron you seem to have 1st class knowledge on turbos, Is there any way to test the vnt whilst the turbo is off the car?? only asking as someone is selling a turbo and they say the actuator is broke but easily replaced off my old turbo. Cheers Tommy
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    There really isn't anyway you can test for this on the engine without fitting a digital boost gauge like mine to plot graphs of boost over time and see how the turbo is responding to demand.
    If it is not effecting the driving, I would leave it alone for now. The only option to check the turbo over is to remove it. Out of interest, do you have a boost gauge fitted at all? If it is slow to respond, you may experience large boost spikes too when changing gear or suddently increasing accelerator demand.
    May 2011
    lancs
    No Mate no boost gauge fitted but will be doing when i rather fit another turbo or full engine with turbo attached. What pipe do i tap into when i do get round to fitting a boost gauge. Thanks Again Tommy
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    You can get a self sealing fitment any of the rubber hoses post the turbo or have a custom pipe made up with a nipple on it. I would recoment using the last pipe before the inlet manifold.
  1. 2.2.dti turbo noise
    By andy_richmond in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2012, 12:28
  2. 2.0 turbo noise
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 28th August 2012, 21:42
  3. Turbo Actuator valve - Squicking Noise - cdti 150
    By digitalinkjetman in forum Engine & Drivetrain
    Last Post: 25th December 2011, 00:29
  4. 3.0 cdti turbo noise?
    By ziplex in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2008, 22:39
  5. Turbo noise?
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2008, 23:20
