Results 1 to 10 of 11
Thread: Need a little help as it wont start after tinkering!
    Regular Member bulletproofpanda's Avatar
    Sep 2010
    Nottingham
    Default Need a little help as it wont start after tinkering!
    Had the engine in pieces this afternoon. Had sprayed a tin of 10K Boost into it a week or so ago but since have had "limp mode" and the spanner light on if taking the car over 3/3.5k rpm which means not taking it over 70mph!
    Took the EGR valve off and cleaned it, took the inlet manifold off (assuming it is this - the bit the egr fits into) cleaned the boost sensor and the bit that plugs into. To take the manifold off I took the metal fuel lines off.
    Have put it all back together and now it turns over but wont fire. My assumption is there is a fueling issue with a possible air lock(?)
    Long story short I need the car for tomorrow lunch time and up a creek at the moment....
    Any help much appreciated
    scotland
    why did you have it in pieces ? what was the initial prob ??
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    I would say fuelling possibly as the DTi's aren't self bleeding apparently.
    Insignia VX-Line Nav CDTI 170.
    Sep 2010
    Nottingham
    Gazza4 - That was what the haynes manual says...
    Anyone know of any ways to recitfy this without the pukka vauxhall bleed kit?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by bulletproofpanda View Post
    Assuming it is air in the fuel system, easiest way is to tow-start it
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Yup sounds like air in the system. Either get someone to tow you down the road in gear for a few hundred yards or slacken off the nut on one of the injectors and crank over in spurts until diesel starts to drip out. The DTi engines aren't self priming.
    Sep 2010
    Nottingham
    Brilliant... For the towing option.... do you need the ignition on? Am I in essence trying to bump start it? Sorry for the bone nature of the question!
    wirral
    26 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    You could try spraying carb cleaner or something of the likes straight into the inlet that should help draw the fuel through once the cylinders are firing
    wirral
    26 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Basically is bump start mate yeah. Ignition on so that you've got electrical signal to fuel solenoid etc.
    Then put in gear. I usually do 2nd hold clutch down once you've got adequate speed lift clutch and it should start your engine
    Sep 2010
    Nottingham
    Update! Towing option taken and worked a treat - Thanks for the advice
    Got the car to the local garage, £48 for a play on the diagnostics machine which I thought was a bit steep but the bloke said it you have any reoccuring problems bring it back and have another plug and play for free so not that bad, and it was the boost sensor that was showing as a fault which was fixed by refitting a small tube that had come off so running OK again!!
  1. Help car wont start. 2.2 dti
    By Middo in forum Engine & Drivetrain
    Last Post: 25th June 2012, 23:09
  2. car wont start? :(
    By ben2996 in forum Troubleshooting
    Last Post: 24th March 2012, 12:30
  3. help car wont start!!
    By vectragsi3.2 in forum Engine & Drivetrain
    Last Post: 11th December 2010, 03:51
  4. 2.2 SRi wont start
    By karlos007 in forum Troubleshooting
    Last Post: 3rd December 2010, 16:37
  5. Car wont start - please help
    By zafira in forum Diesel Engine related
    Last Post: 6th November 2010, 14:25
