Thread: Catalyst system efficiency below threshold bank 1 not present
    Worksop
    Default Catalyst system efficiency below threshold bank 1 not present
    Eml came on with this code wots it mean o2 sensors?
    May 2011
    bispham, blackpool
    Quote Originally Posted by tomo41 View Post
    lambda sensor 2 hours ago had to fit one on mine very easy to do just burnt my arm a bit as you need to get engine hot to unscrew it 21mm spanner needed my fault was sensor one bank one (v6 engine)
    Worksop
    top or bottom one bud
    Regular Member PORKBALLS29's Avatar
    Epping
    Hey mate. BAnk one is the first sensor it fits in the manifold to the right hand rear side of the engine it look, like a spark plug with wires coming out of it.
    May 2011
    bispham, blackpool
    it was the top one the one before the precat nearest to manifold i just removed it and hopped it was the right one
    after i fitted it i put it stright back on the computer to reset eml
    dont know if you leave it it might go off on its own not sure but i have one here so thought might as well
    Worksop
    are they a ***** to get out
    Worksop
    Lol think I've found problem top lambda were loose
    Worksop
    Still getting this keep erasing code but comes back a hour or day later any ideas
    Worksop
    Blowing flexi throw the code up?
  1. P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
    By winty234 in forum Engine & Drivetrain
    Last Post: 8th May 2016, 13:33
  2. Tyre efficiency labels
    By stephen_brady in forum Handling & Braking
    Last Post: 21st November 2012, 14:16
  3. chrome threshold strips
    By tyler boy in forum Styling
    Last Post: 28th March 2011, 20:18
  4. Catalyst help
    By vectra 120 in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 18:03
  5. hmmm catalyst converter
    By Kamikazy in forum Tuning
    Last Post: 22nd September 2006, 04:19
