Results 1 to 10 of 13
Thread: HELP! before the hammer comes out!
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    Default HELP! before the hammer comes out!
    ok so iv read the how too and iv re read it and read it some more but for the life of me i cant get the lens out the map light (the big plastic lens) and i can feel me getting the hammer out and smashing it out so im asking am i doing something wrong?? all i wanna do is take it all off so i can hover behind it so any help would be nice
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    About mid-way along the windscreen edge of it is a 'flat screwdriver entry point'.... slip a flat screwdriver into that (about 5mm wide) and GENTLY use it to 'hook' the lens back and down - the lens should rotate around it's two moulded in 'hooks' on it's rear edge.
    Sep 2010
    in a box
    Quote Originally Posted by Handyandy-UK View Post
    tryed feel like im gunna snap it. iv taken the sensor bit off do i need to take anything off??
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Removing the sensor panel can be helpful, but as long as you just slowly ease the screwdriver (or whatever you are using) forward so the tip hooks the lens fractionally back and then down, you should be fine...... the lens (or fresnel diffuser) does flex a good bit.
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Get the hammer out and be done with it A new one will pop back into place a lot easier
    Quote Originally Posted by Big-Pete View Post
    Not like you to advocate aggression Pete ................
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    Im not naturally aggressive Terry
    Sep 2010
    in a box
    ok so i got ****ed with it and iv snapped it ****ing thing and to top it off it it ent help one ****ing bit light panel still in there undone all screws and its like its all glued to the roof liner ****ing grrrrrrrrrrrrrr
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    It may have been off before and glued back together?
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The lamp holding panel is held in place by those 3 screws to the front and it is also clipped to the 'hole' by a plastic tang in each corner...
    ... so if you were refitting the whole assembly you would offer it up into the hole in the roof linging and push up until it clicks into place.... then fit the 3 screws to secure it all in place. Finally you would fit the fresnel diffuser (if you hadn't broken it)
  1. Can i take a hammer to my vectra!!!
    By Jax in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2011, 18:25
  2. 360 Ban-Hammer again!
    By moorlander in forum Games Room
    Last Post: 28th November 2008, 13:21
  3. hammer time again....
    By leeandjude in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2007, 12:11
  4. before i take a hammer to my car......
    Last Post: 22nd April 2007, 13:25
