Thread: spanner light with no code again
    May 2008
    Wiltshire
    Default spanner light with no code again
    Driving to work and the spanner light came on again the last time was 2weeks ago. No codes stored, light goes away on restart. There is a loss of power when light is on, otherwise car runs well.
    have made sure egr is clean, manifold and egr are only 2yrs old, approx 12000 miles. Am going to change fuel, air filters.
    One strange thing is that the light came on at the same part of the journey, whilst slowing down to a 30limit. Temp this morning was 6oc so don't think its glow plugs? Any ideas????
    Jun 2011
    Elland
    How are you reading the code? Someone more knowledgeable than me will probably quote the correct numbers, etc, but some readers will only read check engine codes (engine light), but the spanner light needs something like OP COM to read what code is stored. Avoid the 'ELM 327' interface ones, as they won't read spanner light codes.
    I bought a cheap code reader and had the same problem when a spanner light came on for a glow plug circuit fault. A reader that can investigate the multitude of other ECUs will probably see the code, even though the spanner light has now gone out.
    Engine : 1.9 CDTi
    Quote Originally Posted by hebblemarine View Post
    What software were you using as my ELM327 interface reads fault codes fine.
    Jun 2011
    Liverpool
    try cleaning the boost sensor aswell.
    May 2008
    Wiltshire
    Just using a cheap scanner from ebay, has read all codes in the past, will try to get it read on a better one. Will clean the boost cenor.
    Jun 2011
    Elland
    Quote Originally Posted by lee gsi View Post
    it came with PCMSCAN software - seems that software can only talk to the engine ECU & I didn't have a 'check engine' light, only a spanner light on. OPCOM talked to the whole lot and found the stored codes as well.
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    Could be your glow plugs fella
  1. spanner light but no error code
    By danno91 in forum Engine & Drivetrain
    Last Post: 12th October 2011, 19:20
  2. Spanner light, but no code.
    By hothatch in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2011, 22:55
  3. spanner light with no code again
    By iasha in forum Engine & Drivetrain
    Last Post: 22nd August 2011, 16:41
  4. Spanner Light, No Code, Poor MPG - WHY?
    By markluk in forum Vectra C / Signum Troubleshooting
    Last Post: 17th March 2009, 13:48
  5. Spanner Light with P1191 fault code?
    By simp_2.2sri in forum Vectra C / Signum Troubleshooting
    Last Post: 16th October 2008, 20:14
