Results 1 to 3 of 3
Thread: Clutch - is it just me...
    Regular Member GoldenWonder's Avatar
    Durham
    Default Clutch - is it just me...
    Its it just me or is the clutch on my 2006 1.8vvti a right so and so to get a clean getaway? I find it quite high biting and 1st to 2nd is hard to do smoothly!
    I've had a lot of cars and didn't notice this on my older 2004 CDTi but I find this clutch quite 'sudden'! Seems to be ok otherwise and doesn't seem to be slipping or anything like that.
    Feb 2011
    Selby
    Seems fine on my 2004 1.8 - though I'm used to some very snatchy, heavy clutches drag racing in the likes of a modified Renault 5 GT Turbo (with Volvo 440 clutch as it has a higher clamping force) and a Pulsar GTI-R (with Exedy clutch)...
    Just takes a bit of practice to control the clutch pedal against the spring pressure, rather than letting the clutch push your foot up. After a while it becomes natural.
    What I can't get on with is floppy clutches (like on some Fords) where there's virtually no spring pressure.
    Durham
    Yeah it does feel like theres a fair amount of spring pressure at the bit point - not heavy as such, just 'springy'!
    Its only got 35k on a 2006, so might be still bedding in
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
