Results 1 to 10 of 13
Thread: Lowered 30mm
    Full Member spennny's Avatar
    Blantyre
    Default Lowered 30mm
    So i am getting conflicting advice
    My car has been lowered 30mm on standard SRI shocks, now do i need to go and get a wheel alignment done
    The post below suggests i should but i have been told i dont need to, the car is a Sri
    http://www.vectra-c.com/forum/showpo...5&postcount=10
    Should i wait till i have changed my upper control arms, ARB bushes , track rod ends and drop links before doing it
    Regular Member PORKBALLS29's Avatar
    Epping
    I've all ways been told that when you change springs/shocks that you should get the car re aligned afterwards. And I would personally prefer to pay £40 to have that done than £400 for new tyres when they all end need replacing at the same time due to odd tyre wear.
    Blantyre
    Ok, now should i take the jpeg along with me and ask them to set it up according to that ?
    Or leave them to their own devices
    Epping
    I suppose it depends if you trust them or not? As they will probably set it to manufacturers standard which if you think about it will probably be wrong as the car has been lowered by a further 15mm. I'd say take it and see what they say. I was lucky as the garage I take my car too are pretty clued up and also have there own race cars so understand that the adjustments have to be made to include the lowering of the car.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    They should have the settings for the vectra "sport" setup anyway
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Guy Set My 1.8 LS Up As An SRI (Sport)
    Worked For Me Mate
    swansea
    I always suffered abnormal tyre wear on my sri, until I changed shocks, springs, rear arms, front links, and rear bushes. I had the tracking adjusted and all is now fine. The car is now 15mm lower. The tyre wear was being caused by worn suspension. Can't see what you can adjust/set, if you lower the car , it is then non-standard. PS, I still think the b4s are too soft for an sri.
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Quote Originally Posted by jrh1 View Post
    Thats because they arent designed for the SRI. They are a replacement for teh standard shock. The B6 is the SRI replacement (or B8 if you want even better handling)
    Regular Member Jezzy's Avatar
    S.E
    I'm no expert, but don't you need full four wheel alignment after new springs and shocks, rather than the £35ish front alignment that all tyre places do? If so, that's about £60-85, not £35-40.
    Epping
    Thats a first Jezzy - you not being an expert on something
    Mine was four wheel alignment for £40
  1. Show me your 30mm lowered cars
    Last Post: 15th July 2012, 16:46
  2. 30mm eibachs
    By Graeme01 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2010, 15:13
  3. PI 30mm Lowering
    By beethamwest in forum Handling & Braking
    Last Post: 3rd April 2010, 13:41
  4. 30mm springs???
    By stuee in forum General Chat
    Last Post: 2nd March 2009, 00:12
  5. New Spring -30mm or new shocks and springs -30mm
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2008, 12:51
