Results 1 to 10 of 17
Thread: 1.9 cdti loss of power
    May 2011
    Unhappy 1.9 cdti loss of power
    Hi Guys,
    My 55 plate Vectra 1.9cdti 120 has suffered from a loss of power. It is almost like the turbo is not working. This has happened since a new thermostat was fitted and the EGR valve cleaned. I have no warning lights showing.
    I know longer get the turbo kicking in when it should or the whistle it makes. The car is not using anymore fuel or smoking or sounds any different.
    Any ideas? The car drives fine but doesnt pull like it should.
    Thanks for any help
    Mark
    Aug 2010
    Derbyshire
    Quote Originally Posted by mark1484 View Post
    Hi Guys,
    Thanks for any help
    Mark
    Funny I should be reading this as I have had the same, but all is ok now strangely.
    First off around three weeks ago I removed the EGR to give it a clean, and also clean the inlet manifold part where the valve bolts onto. This bit can be clogged up as well. New gaskets fitted and reconnected. The EGR valve was freely working and looked pretty newish in there, no need for a complete strip down. Swirl valves and bar all seem to be connected and working. Checked all vacuum pipes all seem ok no splits. I then ran some EGR valve cleaner 3 through the inlet manifold for good measure.
    Previous to all this I cleaned the boost sensor, oil and filter change and air filter change.
    Now I went on my holidays and everything was working fine. Not the fastest from a standstill still got that lag but better for the cleanout and running nice and smooth. It wasn't all that bad before all the cleaning work but getting a bit sluggish all the same. So after a 500+ mile thrash up and down the motorway returning good mpg I was happy. Until Saturday last week the day after I returned from holiday, the Signum just wouldn't pick up from standstil, I really had to give some for it to pull away. Once on the move it really goes though.
    Now today when I started it from cold it really is a different car, a real animal it's as if I had it remapped. I can't believe how different it is.
    I was going to either run some more EGR cleaner through it or strip the EGR again.
    Will see how it performs over the next few days.
    Strange one this!
    Sorry for the essay but hope this helps your question.
    And BTW the only thing that's changed is I stuck some more fuel in it, but from the same garage even using the same pump, so it can't be that.
    Mick
    May 2011
    Thanks for the help, i hope its sorts itself out like yours has done!! If not, will try the boost sensor.
    Mark
    May 2011
    It is still the same? Do you think if i get the engine diagnostics done that might help me find out whats wrong?
    Aug 2010
    Derbyshire
    The small vacuum pipes, check for small splits, holes, especially on the stress points, bends etc.
    Mick
    May 2011
    Thanks Mick, Will have a look this weekend.
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    EGR stuck/sticking
    Swirl valves stuck/sticking
    Vacuum control line perished/split/leaking
    Turbo actuator leaking
    Turbo VNT vanes sticking/stuck
    Split boost hoses
    Leaking intercooler
    Pressure sensor fault
    Throttle valve (butterfly valve on the side of the inlet manifold)
    Clogged DPF/CAT
    So many potential faults and it only takes one.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Its a 120 so no need to worry about the swirls.
    My money is on the EGR following the clean.
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Good point, well made.
    If there are no warning lights, I would not have thought the ERG was very likely.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by nutron View Post
    You won't get any warning lights if its sticking, or not quite sealing properly.
  1. 150 CDTi power loss
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 15th December 2011, 12:48
  2. Loss Of Power On 3.0 cdti sri - please help
    By L.Hamilton in forum Engine & Drivetrain
    Last Post: 14th June 2011, 18:00
  3. 1.9 CDTI 150 loss of power
    By Nick_206_180 in forum Engine & Drivetrain
    Last Post: 22nd January 2009, 20:57
  4. loss of power 150 cdti
    By SRI-150 in forum Engine & Drivetrain
    Last Post: 17th May 2008, 14:24
  5. loss of power 1.9 CDTi
    By ALD in forum Engine & Drivetrain
    Last Post: 5th January 2007, 16:25
