Results 1 to 10 of 14
Thread: HIDs Direct CANBUS Pro kit
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Default HIDs Direct CANBUS Pro kit
    Hi guys.
    Ordered this Monday night, got an email yesterday to say it had been sent out and just turned up now. Got the drill bit etc to fit (I think - time for a root in the garage) but I'm a bit confused by the wiring. I know the wires already on the ballast connect to the bulb, and I plug the existing wiring harness into the other connector on the ballast, but I have plugs left over. There's two wires with spade connectors on the end and these are coming out of the rubber grommit that will sit on the plastic cover over the back of the light and one connector which is the same as the one on the ballast but it can't possibly plug in there because then there wouldn't be anywhere for the power to connect.
    Needless to say, the instructions are not written in the best English and the wiring diagram doesn't show the extra wires.
    And yes, they are H7 bulbs for a preface.
    So, help! Have the bulbs been marked up wrong or something? Someone else must have this kit fitted and working, I hope!
    WGAF#5
    the 2 spade connectors plug into where your existing bulb terminals would sit on the standard h7 (take the standard bulb out and your left with the plug with 2 terminals in it) ...... and therefore power up the Hid
    this then gets pushed into the headlight housing neatly out of the way
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Ah okie dokie. I'll go and have a go in a bit - see if I can work it out. I see what you mean. What about the other end of that connector though? Surely that has to go somewhere. On closer inspection the two spade connectors go through the rubber grommit and connect to the black connector that looks like it fits the ballast. I'll get some photos in a sec.
    WGAF#5
    hopefully this diagram will make sense ...if you lay it out it will only connect together one way
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    *light bulb just lit up moment*
    Ah I see how it works now, got there in the end! The diagram in the book doesn't show anything like as much detail as that. It's a bit pants compared.
    Thanks a lot mate.
    WGAF#5
    Quote Originally Posted by cont1204 View Post
    Thanks a lot mate.
    lol thats a HID ignited moment ... let us know how you get on
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Well, I didn't get very far because the 21mm hole saw I thought I had is actually 25mm.
    WGAF#5
    10 pence piece and a stanley knife
    mind your fingers and dont do it on the dining room table .... you wont be popular
    Jul 2010
    Yorkshire
    man of experience speaking? lol
    WGAF#5
    Quote Originally Posted by urbanfox View Post
    only the cutting of the backing plates .... seen the fingers and tables done by someone else lol
  1. HIDs-direct
    By KyleSxi in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 16:13
  2. HIDs with Half Canbus
    By M65 in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2011, 17:11
  3. Hids-Direct...
    By chris198 in forum Electrical & ICE (including SatNav)
    Last Post: 13th April 2011, 13:26
  4. Hids Direct
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2009, 23:36
  5. hids direct
    By 06 vectra in forum General Chat
    Last Post: 5th February 2009, 23:54
