Thread: Programming key fob without security code?
    Regular Member AlexGSi2000's Avatar
    May 2011
    Liverpool
    Default Programming key fob without security code?
    Morning,
    I have a Vectra C SRi CDTi - basically, the unlock button on the keyfob has stopped working. - All other buttons work fine.
    Question is, if I get a replacement / 2nd hand fob from ebay, will I be able to programme it by holding down the lock / unlock buttons whilst the ignition is in position 2?
    The immobiliser is fine, so would just swap over the remote part.
    Reason being, the car pass that came with the car doesn't match! - want to avoid having to purchase a new one from the dealers if possible.
    Many thanks!
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    As long as you just change casing every thing should be fine
    Irmscher Insignia CDTI 130
    May 2011
    Liverpool
    Quote Originally Posted by bigmac View Post
    Not the casing, its the actual remote locking circuitry that will be swapped.
    I will be leaving the key blade and transponder the same.
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    Hes saying its the button itself... Not the casing....? The answer is no, the vectra cannot learn remotes in that fashion unlike the fords (i think) do.
    11 Post(s)
    If you're a dab hand at soldering, just swap over the microswitches from the ebay fob to your PCB.
  1. Where can I get my car security code?
    Last Post: 28th February 2012, 02:22
  2. no security code for cd70
    By pipamish in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2012, 02:14
  3. Security code
    By stevie16v in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2011, 03:38
  4. Security code
    By edgaras in forum Electrical & ICE (including SatNav)
    Last Post: 31st December 2010, 03:29
  5. Radio Security Code
    By sriturbo in forum Electrical & ICE (including SatNav)
    Last Post: 23rd November 2009, 11:41
