Results 1 to 10 of 11
Thread: Help please 1.9cdti
    May 2011
    Chesterfield
    Default Help please 1.9cdti
    Hi all I have had my 150 1.9 cdti around 2 months and this is second time I have noticed it on my 10 mile motorway drive to work cruise control at 70mph and I am struggling to reach 35mpg (normally 45)
    I just can't get my head round it any ideas it's done 39k
    Thanks matt
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    think to achieve your best mpg you would need to get your car up to optimum temp and on a 10 mile journey your engine will be barely warm.
    and don't always go by the obc as it's very rarely right
    Woodbridge
    Has it been serviced? Are you just going off the trip computer or have you calculated it when fueling up?
    May 2011
    Chesterfield
    The trip comp it's usually spot on tbh and it's warm by slip road I do a few miles before and have it ticking over for a while before set off
    Serviced before I got it by vxl
    May 2011
    Chesterfield
    Cheers for the prompt responses but it's on the fuel gauge and obc I know these are variable and tht but usually I gain on obc reading not loose and thi is only every now and then it's usually great
    Barrow In Furness, Cumbria
    If you leave it ticking over for a while then your MPG will drop massively as you're burning fuel while not moving.
    May 2011
    Chesterfield
    I mean whilst driving obc is saying like 32mPg when normally I'm up at 45-50 this is once every now and then that's why I don't get it :s
    Jul 2010
    Yorkshire
    Dpf regen?
    May 2011
    Chesterfield
    That's what I thought but how often does it do it
    Sodding Typical on Sea
    Quote Originally Posted by urbanfox View Post
    Dpf regen?
    Only if an estate though,,,
    As for economy this type of running isn't the best for economy, I can frequesntly see single figure mpg on the instant econ readings while accelerating through the gears on inclines etc and in daily grind 40mpg or less is pretty realistic.
    on long motorway run's I can easily get over 50mpg all day but in volume traffic and on commute's 35/40 is all to easy to see.
  1. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  2. 1.9cdti sri 120
    By dsimpson15 in forum Introduce yourself.
    Last Post: 21st April 2012, 19:24
  3. 1.9CDTI 120 55 reg
    By rjw in forum Cars for sale
    Last Post: 15th March 2011, 15:28
  4. De-Cat 1.9CDTI
    By gregc in forum Diesel Engine related
    Last Post: 26th January 2009, 10:33
