Thread: Brake lights ( how many bulbs )
    Regular Member HITFACTORY1403's Avatar
    Mar 2011
    NEWCASTLE UPON TYNE ( Shiremoor )
    Default Brake lights ( how many bulbs )
    my computer is telling me , i have a brake light bulb problem .
    when the brake is pressed .....
    the left brake light is only half illuminated compare to the right brake light .
    so am i right in thinking each brake light has a top and bottom bulb .
    please see attached photo , i hope it helps describe what i mean .
    thanks for any replies .
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    The brake lights are the top ones. If one blows, the lower one takes over. So looks like your driver's side top bulb needs replacing, as the bottom one is lighting up
    It's a 21watt single filament bulb.
    EDIT>> If the top one is still lit, with the lower one on the same side, it means the top one is *about* to blow
    Glasgow
    2 brake lights but the tail lights also light up when you brake.
    The one that isnt working needs replaced.
    Mar 2011
    looking from the top of the rear lights .
    1) clear indicator .
    2) skinny red brake light .
    3) fat red night light . ( tail light )
    just been out to have a play with the lights and jam a pack of Huggies nappies on the brake peddle .
    it appears i am missing the driver side skinny brake light
    and the fatter red night light ( tail ) is compensating for the lack of a brake light .
    Yes ! ......... what he and him said up above ...... l.o.l.
    Thanks Guys For Confirmation ....... cheers
    11 Post(s)
    Should be from the top.
    Indicators
    Tail & brake lights
    Tail lights (which becomes a brake light should the original tail/brake light fail)
    Fog light (drivers side only - UK)
    Reverse lights.
    All bulbs are 21 watt single filament bulbs. The tail light runs at a reduced voltage until the brake pedal is pressed, then full voltage is applied to make it brighter. Clever stuff this canbus network.
    If you've got clear indicator lenses then you need a coloured bulb with offset pins.
    Mar 2011
    so under the indicator ... ( when working normally )
    the skinny brake light AND the fatter tail light are BOTH on permanently ...
    but when you brake ONLY the brake light gets brighter ?
    Is this correct ?
    it's very clever stuff , having the tail lights take over as brake lights , good safety measure .
    11 Post(s)
    The tail lights shouldn't come on when you brake, unless you've already got your headlights switched on.
    Mar 2011
    o.k. ......... thanks for all your help .
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. rear brake bulbs
    By dodus in forum Electrical & ICE (including SatNav)
    Last Post: 4th March 2013, 22:40
  3. HID Bulbs for fog lights on Vec c
    By simmo3187 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd March 2012, 19:50
  4. Bulbs for brake lights?
    By mishima in forum Vectra C / Signum Troubleshooting
    Last Post: 12th May 2011, 15:06
  5. Brake Light Bulbs....
    By Signum_CDTI in forum Electrical & ICE (including SatNav)
    Last Post: 23rd November 2007, 12:49
