Thread: signum turbo problems
    Jun 2011
    fife
    Default signum turbo problems
    Hi folks, got a stange one for you.
    I have a signum 2.0 turbo z20net. which i bought with a dead engine. So i purchased a new engine with less than 20k on it, and proceeded to fit the new engine in to the car, repacing only the engine and using all of the original cars electrical components and mechanical bolt on parts.
    Once it was all fitted and put back together we then went for first start and the starter just keeps engaging and turning the engine over ?.
    So we removed the solenoid wire from the starter and turned on the ignition and fed the solenoid post power and the engine started first time and runs sweet as a nut.
    So the car runs excellently with the solenoid wire off.
    So we plugged in the modis and it throws up some weird codes ?
    It says low voltage to boost control valve and low voltage to somewhere else, cannot remember where.
    so as it was running ok i took it out for a shake down test and the turbo does not do anything. The actuator and the turbo are brand new. But no boost.
    Please help. I just hope someone else has had weird problems like mine.
    Thanks for reading.
    Any help is most welcome and thank you in advance.
    regards
    Sandy.
    Regular Member stuartbat's Avatar
    May 2008
    shropshire
    boost control valve
    these will be the problem i suspect as when they are faulty the turbo holds back some what
    I have had this problem last year also repalced both valve and then all has been okay ever since have a search around there are a few posts about the boost control valves/solonoids
    Jun 2011
    fife
    cheers stuartbat, will try to get them ordered asap
    Quote Originally Posted by stuartbat View Post
    boost control valve
    May 2008
    shropshire
    there are 2 you know 1 by the turbo and 1 under the engine cover
    Jun 2011
    fife
    cheers mate, will get them ordered and see how i get on.
    Engine : 1.9 CDTi
    If that doesnt work I suspect its the starter as I have had this twice before on other cars.
    When your cranking the ecu sends most of the power to the starter and minimises power going to other items. It uses the solenoid wire to sense if your cranking.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved to correct section
    Irmscher Insignia CDTI 130
  1. signum turbo problems
    By sandy white in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd July 2011, 19:56
  2. Turbo problems?
    By warren77 in forum Engine & Drivetrain
    Last Post: 14th May 2011, 12:04
  3. Turbo problems on my signum 2.0dti
    By cookieboy in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2010, 12:54
  4. Turbo problems?
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2006, 15:12
signum 2.0 turbo problems
