Thread: who as a dump valve fitted to there veccie turbo z20net
    Worksop
    Default who as a dump valve fitted to there veccie turbo z20net
    as ive seen mixed reveiws
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    Haven't heard of anyone with one on here. The z20net has a recirculating valve and apparently fitting a standard dump valve will make you loose power.
    I'm sure someone else knows abit more about them than me but there pretty much a no go I think
    Worksop
    Don't think forge supply the kits anymore
    Regular Member accveccysriturbo's Avatar
    Jul 2010
    west mids
    Correct from what I have gained from the site is that the engine itself already has a recirc valve, and fitting an aftermarket one causes/can cause issues
    Worksop
    Yeah it as but u can blank it off and fit a aftermarket one
    Jul 2010
    west mids
    So if you know the answer already are you just trying to source one?
    Worksop
    Quote Originally Posted by accveccysriturbo View Post
    Yes bud were wondering wot needs doing to fit etc and were vac pipes need swapping etc
    Feb 2011
    leeds
    Jul 2010
    Yorkshire
    There may be a good reason why it re-circs.. I know on the Vag 20vt engines its to help with AFR's etc. The Maf sensor can get all upset if it doesnt see the recirculated air come back in..
    Not sure if it is in the same with the z20net's though..
    Regular Member Jezzy's Avatar
    S.E
    The boost recirculates in order to keep the turbo spinning: When you back off the accelerator, instead of the unwanted boost "braking" the turbo, or being dumped to atmosphere (dump valve), the boost bypasses the cylinders but keeps the turbo spinning, so that when you press the accelerator again the turbo doesn't have to spool all the way up again. I can't see how disabling this system and instead dumping the boost is going to help.
  1. Z20NET and a dump-valve
    By hog in forum Engine & Drivetrain
    Last Post: 16th June 2012, 17:34
  2. Dump valve fitting z20net
    By tomo41 in forum Engine & Drivetrain
    Last Post: 14th July 2011, 13:14
  3. How many sensors from turbo back on a z20net veccie
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2011, 19:03
  4. Dump valve fitting help on z20net
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2010, 21:47
  5. Z20net dump valve Help!!!!
    By dansis in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2010, 14:23
