Results 1 to 3 of 3
Thread: 4th injector misfiring ??
    North west
    Default 4th injector misfiring ??
    Has anyone had this problem with their 1.9cdti 150 (05) ?
    I have just had a new inlet manifold and EGR valve fitted and the garage said today it is still showing as misfiring on the 4th injector ? They reckon it is only a small problem so I'm assuming I wont be able to feel it is such, not picked it up yet so wont know until tomorrow the extent of it...
    Any ideas ??
    Thanks.....
    North west
    ...anyone... ??
    incidentally I picked up the car today and it is tons better, however if the slight misfire could be an easy fix I would crack on with it...
    Regular Member mozzer99's Avatar
    bristol
    I've eventually rewired all 4 injectors as the car approached 150k 3 out of the 4 had failed.
    Makes sense really that identical wiring to the third injector for all the others would likewise fail sooner or later.
    I still had a judder so checked all the connectors of a similar type on the engine. They looked fine but a squirt of contact cleaner/lubricant on each solved it. Trouble is as I did them all at the same time I don't know which one it was!
  1. Engine misfiring
    By Gworld247 in forum Engine & Drivetrain
    Last Post: 13th May 2012, 08:53
  2. signum misfiring
    By x111pow-signum in forum Engine & Drivetrain
    Last Post: 13th October 2010, 21:58
  3. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
  4. Misfiring?
    By daryl turner in forum Petrol Engine related
    Last Post: 27th January 2010, 15:34
vectra c 4th injector problem
