Results 1 to 10 of 25
Thread: is it ilegal
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default is it ilegal
    i know its ilegal to drive with fog lights on but is it ilegal if i change the bulbs with leds and have them on?
    retro fitted my fogs so wont have the warning light on with leds
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The basic difference with front fogs is that they are mounted lower, and have a wide, flat beam pattern - the wide part could be dazzling to oncoming traffic in non-foggy conditions, thus driving with them on is illegal unless in reduced visibility.
    The manner in which the light is produced, be it incandescent, led or other has little to do with it if the beam pattern produced is the same ie wide and flat.
    With rear fogs it is the greater intensity or brightness that makes it a foglamp. Again, the method of producing the light is irrelevent if it is noticeably brighter than normal rear lights under normal, clear conditions.
    Oct 2009
    Sandwell
    saying that tho you see these merks with much bright LEDS down by the fog lights
    Apr 2011
    essex
    Yes day time running lights
    http://www.halfords.com/webapp/wcs/s...egoryId=245215
    Im sure pc plod will still ask u to turn them off
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Those vehicles with the led daylight running lights as standard will have had them approved prior to the model receiving type approval, so whoever dishes out the E mark is happy they are not too bright or produce an unacceptable beam pattern.
    Take a gander at RVRLs and as long as you are happy you comply, then don't worry.
    http://www.legislation.gov.uk/uksi/1.../contents/made
    Regular Member scotty84's Avatar
    Dec 2010
    Boosting in W.Mids
    Vehicle : Saab 9-3 Aero
    Trim : Aero
    Engine : 2.8 Turbo V6
    Mileage : 62000
    Dont mini's have driving lamps? Like just above the fog light lamp?
    Plus agree with Chris ive seen some new cars and there Daylight leds are dazzling bright lol.......Ive seen a few cars about that have side lights in the fog lamps.
    I was thinking of doing it.
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Actually, just having had a quick gander through RVRL 1989, Sch 6, there isn't a great deal of actual regulation on front fogs as long as they are postioned correctly, show white or yellow light, are adjustable when you're stopped and they bear an approval mark. Legally, it seems very lax.
    Oct 2009
    Sandwell
    i brought some H3 smds and they aint that bright they just make the car look good at night, and look cool with the hids
    Jun 2007
    Wirral
    Quote Originally Posted by chris1804 View Post
    Driving with foglights on will get you pulled as plod think if you are ignoring one law then you may be ignoring others - even if you're not you'll still be delayed. Two cars with foglights on park near some gents toilets near where I drive to work, it must be an electrical problem as they seem to have their bonnets up as well...
    Regular Member Mr Hyde's Avatar
    Feb 2011
    Suffolk
    Bottom line buddy - yes it's illegal. Doesn't matter what bulbs you use, they will still be fog lights. Drl's and mini type lights as said are type approved.
