Thread: Best Footwell/Floor Lights
    Regular Member UltraVec's Avatar
    Jun 2011
    Dublin
    Default Best Footwell/Floor Lights
    Whats the best lights to use for footwell lighting?
    Neons? LEDs, SMD?
    Going to be fitting some soon.
    Had a look and they can probably be wired to the ashtray lighting wires in the front or else extended from the roof light.
    Thinks the ashtray light is more easy.
    Looking to do them in a blue.
    Any1 recommend using neons, led strips or smd's??
    Woodbridge
    LED strips, cheap as chips. If it is wired to the cig lighter will they only come on when you turn the lights on? do you not want them on when you open the doors?
    Regular Member farley2708's Avatar
    antrim n.ireland
    this is what i used,1 in each footwell,1 in interior light,1 under each seat for the rear footwell & 1 in the boot
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    boot
    Aug 2007
    North West
    Trim : SRI With a few added extras
    Engine : 1.9 CDTI 120
    Year : 06
    farley: very nice mate, on my to-do list. Are yours wired to the interior light, so they come on when the doors are opened / light comes on? Any canbus probs?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    I have the same set up in the front foot wells 2x 48 led strips wired to the interior light, i also have a 36 led panel wired into the boot of the siggy
    antrim n.ireland
    cheers phil-h,yep wired to the interior light,nice when its dark,you hit the button & she light up all nice n bright
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    defo go for the SMD i brought 5, 4 in front light and 1 in rear and my god there bright
    need to get some for the boot, i like the idea for the footwells
    Jun 2011
    Dublin
    Looks like SMD strip lights it is then.
    Decision made. Thanks.
    And Ginge your right, much better wiring them 2 the interior light.
    Would a separate on/off switch cause any trouble which the canbus system or has any1 had any trouble with it?
    Jun 2011
    Dublin
    Thumbs up Fitted
    Fitted the foot-well lights and the boots 2.
    Used SMD LED strips. Top Notch!
    Wiring the small connections can be a nuisance but got there in the end.
    Thanks 4 helping with the decision.
    In my opinion, make sure to stay away from neon tube ones!
    Pictures should be attached.
    Regular Member nick-v2.2's Avatar
    Nottingham
    I used 24 led strips in footwells and 48 led strips in the boot. from ebay
  1. Under Bonnet Lights & Footwell Lights...
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2013, 09:55
  2. Footwell lights
    By conman in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2012, 20:04
  3. footwell lights
    By brod999 in forum The 'Off Topic' room
    Last Post: 4th December 2012, 23:38
  4. footwell lights
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2009, 19:28
  5. Footwell Lights
    By RMJonny in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2009, 15:12
